Old 02-15-2008, 06:33 AM
Loman Loman is offline
Question How do you re-surface a Scotch-Brite Wheel?
I was carelessly polishing a piece of metal in the shop the other day. Fortunately it was not RV-related - just a bracket for a dramatic prop my daughter wanted for a play she is involved in. I let the piece slip and it went under the wheel where it jammed momentarily between wheel and bench before being shot at the wall behind the benchgrinder with spectacular force .
The problem is that it tore a small chunk out of my Scotch-Brite wheel, which now vibrates and is very unpleasant to work with.
Has anybody found a way of re-surfacing these wheels? Without actually trying it, I guess that the Scotch-Brite will instantly dull any sharp or abrasive surface that you present to it. However, it is a shame to just throw it away.
Old 02-15-2008, 06:36 AM
f1rocket's Avatar
f1rocket f1rocket is offline
I used a dressing tool that came with my bench grinder.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 02-15-2008, 06:40 AM
grantcarruthers's Avatar
grantcarruthers grantcarruthers is offline
I can tell you that a file does NOT work.
The scotchbright won and my file now has a nicely polished spot. I never liked that file anyway, that's why I tried that one.
RV-8, Both wings with top skins on
-4 bought flying
Old 02-15-2008, 07:08 AM
mdoyle mdoyle is offline
I used a portable belt sander. Wear a good dust mask and eye protection, preferably a full face shield. It works well, but of course the dust is abrasive. I wasn't careful enough and it caused me some eye problems for a day.
Mike Doyle
RV-12
RV-9A, Under Construction
Xenia, OH 45385
lrfrey lrfrey is offline
A Dressing tool does work quite well, slow but works as Randy said. But, a file will also. Tke key is to use the "Corner" of the file, not the flat face. Go slow. Bob Avery has a recomendation on dressing the 3M wheel in his catalog.
Larry
Old 02-15-2008, 07:19 AM
Dayton Murdock's Avatar
Dayton Murdock Dayton Murdock is offline
Default Dressing Scotch brite
Hi Loman
In the shop we use a broken grinding wheel. Take a course wheel that you don?t much care for and break it in half or large parts. Use the jagged edges to dress the scotch brite.
Dayton Murdock
VAF#408 RV4 N359DM Flying 1046 hrs 7/16/19
Builder Log
Old 02-15-2008, 07:21 AM
Brantel's Avatar
Brantel Brantel is offline
I used the corner of the end of the file that normally goes into a file handle.
Hang on for dear life and ease it in and work it back and forth. Don't get too aggresive because it might grab and tear a chunk out of the wheel.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 02-15-2008, 07:44 AM
Geico266's Avatar
Geico266 Geico266 is offline
Hey troops, what is the difference between these wheels besides price? Anyone use both? Comments?
http://www.aircraftspruce.com/catalo...inderdiscs.php
http://www.averytools.com/p-349-ligh...de-softer.aspx
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 02-15-2008, 07:49 AM
Brantel's Avatar
Those are two different products intended for different uses. The cheaper one is not a cut and polish wheel, more of a round pad.
The 3M 7A medium wheel is what most recommend.
Old 02-15-2008, 07:50 AM
DavidBurton DavidBurton is offline
Hi Loman,
The scotch bright wheels are made by 3M. If you search their website you will find instructions on how to dress the wheels. We use a tough 40 grit paper. You can even form the face into contoured shapes for special applications. You can also "sharpen" the wheel. It involves jamming a hunk of 2x4 wood into the wheel and heating both to the point of melting/burning. We use this when our wheels stop cutting aggressively. I've never needed it for the aluminum work needed to build an RV. It's more for finishing harder materials like steel. Good luck.
DaveB
RV6
