Old 02-14-2008, 03:03 PM
chepburn's Avatar
chepburn chepburn is offline
Default Yikes! The dreaded tank leak!
OK...
Tank baffles are in place... all shop heads painted with proseal. Time to test the tank using a balloon on the vent line. Balloon deflates after a few hours, and unfortunately, its not the balloon.
There is a small leak on the inboard rib-baffle seam right by the Z bracket. I guess I did not get enough of a proseal bead on the end rib there.
The access cover is prosealed on. Before I remove the access cover and paint the seam, with all that entails, would 'exterior' proseal of the leaking edge be sufficient? Or is a tank like a basement, you can only seal it from the 'pressure' side?
Any suggestions?
Chris Hepburn
Ottawa, ON
RV-8 C-GOGO FLYING
Renew 12/20
Old 02-14-2008, 03:09 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
The most certain and permanent solution is to go in through the access cover. Anything applied from the outside is less certain. I highly doubt you could get proseal in there from the outside, but you could use green loctite as per Van's. (I had one leak that required loctite because it was on the outboard part. It's sealed for now, but I'll always be wondering how long before it fails.) Still, the fact that it's on the inboard part of the tank is, I think, karma telling you to do it the best way the first time. Just my .02, but good luck whatever you do.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 02-14-2008, 07:12 PM
chepburn's Avatar
Default Thanks
Well, I guess it was kind of a rhetorical question....The access cover is off...Im going to re-seal the seam from the inside using a syringe full of proseal. As I suspected, there is an insufficent bead along the edge.
The good news is, the other tank balloon is still holding on strong. Looks like I am only going to need to order one new cork gasket.
Chris Hepburn
Ottawa, ON
RV-8 C-GOGO FLYING
Renew 12/20
Old 02-14-2008, 07:55 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Do a search and you'll see that lots of people don't use the cork gaskets.... I didn't and no air leaks on either tank.
Maybe save the $7 gasket shipping fee?
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 02-15-2008, 10:07 AM
664781 664781 is offline
Default Cork Gasket
Chris,
Don't use the cork gasket! I just pulled my tank because the gasket is leaking after just 2 years......
Kurt Lohmueller A&P, DAR
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
Old 02-15-2008, 04:21 PM
chepburn's Avatar
Default OK ...how many of you DONT use the cork gasket?
Originally Posted by 664781 View Post
Chris,
OK,
Before I seal er up again...how many of you use the cork gasket? I will be prosealing both sides of the gasket before putting it in place. I thought the 'benefit' would be that the cork will provide a sacrifical surface to remove if I ever have to get into the tank again.
Obviously, there are different views on this.
Feedback?
Chris
Chris Hepburn
Ottawa, ON
RV-8 C-GOGO FLYING
Renew 12/20
Old 02-15-2008, 05:39 PM
chepburn's Avatar
Default Nevermind...I just looked at past posts
Nevermind...I just did a search as suggested by IowaRV9. I will look at the proseal-only solution to the access cover.
Chris Hepburn
Ottawa, ON
RV-8 C-GOGO FLYING
Renew 12/20
Old 02-15-2008, 06:10 PM
Mel's Avatar
Mel Mel is offline
I have repaired many leaks caused by the cork gaskets. I use pro-seal only and have never found a leak when it was done this way!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-18-2008, 12:58 PM
caryr's Avatar
caryr caryr is offline
I am sure this will create a stir. ---
you can put a vacuum on the tank and suck the proseal into the leak from the outside.
When I say vacuum, I talking about 10 inches of water in a manometer. So you will need a clear tygon tube to make a manometer.
Thin the proseal with acetone. Maybe the consistency of 30 weight motor oil.
this works very well
Cary Rhodes
Taylorsville, Georgia
N203CR
Van's RV-7
First Flight April 2004
