Old 02-14-2008, 09:09 AM
Michael Burbidge Michael Burbidge is offline
Default Dimple die scratches skin surface
I'm having a really difficult time preventing the dimple die from scratching the surface of my HS skins as I move it over from hole to hole while using my C-Frame to dimple. I've built a table for my C-Frame so that the skin is supported as I'm dimpling. I lift the skins as I move it, or so it seems. But I guess not enough. There is still a light scratch between holes. In any event, the skin is just lightly dragging against the tip of the dimple. But the soft alclad surface is no match for the hard tip of the dimple die.
Do I have a bad dimple die? Does anyone have any tips on how to prevent scratching the surface. These are very light scratches in the alclad. It's very annoying!
Someone should make plastic or nylon tipped dimple dies.
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 02-14-2008, 09:23 AM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
You can try polishing the tip of your dimple die a little better, but in all honesty these scratches are inconsequential. You're going to have 1000s more by the time you are done. Then you're going to take a Scotch-Brite pad or sandpaper to the plane before painting it anyway.
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 02-14-2008, 09:54 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Sounds like you are using some kind of "C" frame device.
Do you have any kind of flat surface "Table top" around the unit??
A couple of pieces of soft foam, a couple of inches to the sides of the die will keep the skins above the die, you need foam that will hold the skin up, yet compress when you form the dimple.
May take a bit of trial and error, practice on scrap.
This worked for me, using a DRDT2------with a "bang-on-it" unit, you will probably need to use one hand to hold the skin down when you hit the plunger.
Good luck.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-14-2008, 09:56 AM
Craig23's Avatar
Craig23 Craig23 is offline
Default Mine too
I agree with Guy. My dimple die does the same thing if I let it contact the skins at all as they move to the next hole. The scratches are so light that they are nothing to worry about and by the time you paint the aluminum you won't even notice them.
Craig Schwartz
RV-8 (Flying!), IO-360B1PC2 (180 hp, 1 P-Mag, 1 Slick Mag), Whirlwind 200RV, AF-3500, G496, Digiflight II, Classic Aero Sportsman Ultraleather Seats
N868RV
Santa Rosa, CA
Old 02-14-2008, 10:03 AM
docrick docrick is offline
Default Happens to everyone
It is no problem they will buff out or if you paint the aircraft you'll never know they were there.
Build on
Old 02-14-2008, 10:38 AM
az_gila's Avatar
az_gila az_gila is offline
Question Reverse the dies?
Can you work it the other way round... with the "pin" of the die on top?
Don't use the return spring, and hold up the C-frame set as you move the skin around... gently let the set down so that the "pin" falls in the hole... then whack it!...
This way, you are moving the skin over the polished "innie" die.
If you leave the return spring on... you will have made a good skin punch...
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-14-2008, 10:45 AM
Geico266's Avatar
Geico266 Geico266 is offline
Gil has it right, put the tip up in the movable part of the "C" frame and the receiver / button part down.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 02-14-2008, 11:18 AM
AMURRAY's Avatar
AMURRAY AMURRAY is offline
Default Turn it over
I agree with Gil. Turn the dimple die over so the male half is on top.
Aaron
RV6 built and flying
Bearhawk Patrol plans purchased
Old 02-14-2008, 11:58 AM
Aaron
I think this would make the process take much longer. With a C frame you would have to be really careful to make sure the male die went into the drilled hole or you'll find an extra hole
This would be a little easier with a DRDT-2 (which I'm fortunate to have and will never part with, at least until my 9a is finished) because you don't have to whack anything with a hammer.
Just don't worry about these little "mars"; they'll buff out. If you don't like those marks just wait until you start backriveting stiffeners on your very thin rudder skins! The back rivet plate will leave little mars as well.
Old 02-14-2008, 12:47 PM
Boy, there's no way I'd ever turn those dimple dies around, at least if you use the C-frame tool as they come...with the little spring and O ring holding the stem slightly above the work.
Having the "male" poking through the hole is the only confirmation that things are lined up properly.
I'm familiar with the problem you describe, and it is unsightly but as others have stated, inconsequential. Still, you should be able to minimize it by lifting the work off the die more rather than dragging it across it.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
