Originally Posted by prkaye
is the alclad on our airplanes made using a process of "galvanization" ? The Rustoleum paints say that they should not be applied direclty to galvanized metal without a primer as a base coat.
Phil, the warning about galvanization doesn't apply to Alclad. However, I suggest you use a primer under the Rustoleum. I've used Rustoleum on many projects over the years and while it is a good paint, it will work best with a primer. I used the PPG industrial wash primer that is common on RV's and have also used epoxy primer and various Rustoleum primers.
Not sure what you are painting at the moment, but if you are painting a large area like the interior with Rustoleum, you might consider applying it with a gun vs rattle can. The paint can be thinned with mineral spirits for spraying, and that will reduce the gloss a little which is good for an interior. The interior of my plane was painted with gun-sprayed Rustoleum nearly ten years ago and it has held up well (primed with the PPG primer). The rattle cans work well for smaller items.
