Old 02-13-2008, 02:10 PM
Drdean Drdean is offline
Default RV-9 Gas and brake lines DrDean.....
Wow I'm not liken' them alum brake and gas lines. Are there any alteritives or am I stuck twisting and turning these lines thrue my bulkheads.
Old 02-13-2008, 02:17 PM
pmccoy's Avatar
pmccoy pmccoy is offline
Default Just Finished Mine
Yep, bending aluminum tubbing can be a real pain. I had to order extra tubing in both 1/4 and 3/8, as I had to create the fuel and brake lines several times before I was happy.
I did order some flexible brake lines from Bonaco, Inc. They have a brake system to replace the plastic tubing used between each brake pad. I think they are also putting together a flexible option for the fuel lines as well.
I think I talked to 'Brett' at Bonaco.
http://bonacoinc.com
If you do a search on fuel lines, I think you find other suppliers as well.
_____________
Peter McCoy
RV9A N35PM S/N:91335
First Flight: April 2013
Hobbs: 400 hours after Oshkosh 2017
www.myrv9.com
Old 02-13-2008, 05:18 PM
Greg Arehart's Avatar
I ran my brake lines around the sides of the fuselage rather than through the holes and down the center console. Seems to make much more sense to me and easier to do also.
I also did the vent lines differently. Ran them straight forward through the bulkhead to the front corners just behind the firewall, then up the corner and back down again. I found this was easier than the planned route. BUT don't skip the up-and-down-in-the-corner part, otherwise you will likely find fuel bleeding out the lines onto the ground. Also make sure there is clearance for any rivets, bolts, etc. that you need to work into that corner.
greg
Greg Arehart
N 7965A
Old 02-13-2008, 10:45 PM
rv9builder rv9builder is offline
Default check out this thread
http://www.vansairforce.com/communit...ad.php?t=15708
Lots of suggestions, including putting AN fittings in the bulkheads.
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
