Old 02-11-2008, 05:49 PM
Oldgeezer Oldgeezer is offline
Default Need help determining wire size
Anyone
Iam in the wiring phase, using an Odyessy 680 battery and Looking at Nuckolls Aero electrical connections book, figure Z-11, it calls for #4 awg wire size from the battery to ground on the firewall and #4 awg from the positive to the battery contactor. I'm using a brass bar from the battery contactor to the starter contactor per Van's instructions and the #2 awg welding wire from the starter contactor to the starter. Is anyone else using this set up and having any starting problems? The two runs of # 4 are probably less than 12 inches long each, and multi strand and very flexible for the tight turns, just not sure if it is the right size.
Oldgeezer
RV9 wiring
Old 02-11-2008, 07:36 PM
captainron's Avatar
captainron captainron is offline
Sounds plenty heavy enough to start a Peterbuilt! I would suggest when making cable with tight turns, to lay out the cable in roughly its final shape while swaging the terminals on, which will relieve strain on the cable strands from trying to bend them to fit later.
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
Old 02-11-2008, 09:43 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Bob says #4 for all...
Actually, the AeroElectric Bob's Z-11 drawing I have (version K) specifies #4 wire for the entire run of the starter circuit - including the contactor to starter run.
Going bigger in wire size is no problem, but according to Bob's schematic #4 is OK....
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-13-2008, 07:34 AM
Default wire size
Thanks for the help guys
Oldgeezer
