02-11-2008, 04:38 PM
Help with FWF kit and Superior XP-360...
I just got off the phone with Vans and they were not a lot of help... Is there anyone with a similar setup to mine that can help me select what to add/remove from the FWF kit before ordering? I have the following:
RV-7A with Superior XP-360 with Vertical Induction, AFP fuel system, One Lightspeed, One Mag.
Here is the list for the O-360 which they said is a good starting point since it is Vertical Induction...
1.00 FF-7A 0-360 CS FIREWALL FORWARD KIT
1.00 AT0-028X3/16X6 FOR F.WALL KIT
1.00 AT6-058X5/16X15 7/8 ALUM TUBE C-610
1.00 SS304-26GAX1/2X9 SCAT CLAMP !!SHARP!!
1.00 FF 3/4 FIREWALL PLUG SS FIREWALL PLUG
1.00 ES PC680 INSTALL KIT BATTERY MOUNT 7/9
1.00 AS3-063X1X12 ALUM STRIP
1.00 EA LV-1 HEAT SHIELD EXHAUST HEAT SHIELD
2.00 CT A-740 BLACK PUSH PULL CABLE BLACK
1.00 DUCT CBT-5/8 COOLING BLAST TUBE
1.00 EA CV HOSE 9816 BREATHER HOSE 4 CYL
1.00 EA DYNA BOLT BOLT SET 4 CYL DYNAFL
4.00 EA DYNA VI-STD VIB.ISO.ALL EXCEPT-10
1.00 EA EXH W/MUFF 320/360 ALL EXCEPT 3/4
1.00 EA OIL COOLER II O-320/360 OIL COOLER
1.00 ES 24021 STARTER SOLENOID 2OUT
1.00 ES 24115 MASTER RELAY
1.00 ES ALTERNATOR DELUXE 60A KIT W/OV PROTECT
1.00 FF-705 BREATHER TUBE
1.00 FF-709 OIL COOLER DOUBLER
1.00 VA-161 GASCOLATOR DOUBLER
1.00 IE VMP INSTALL KIT FITTINGS/HOSES
1.00 GAS-5 GASCOLATOR 117 MICRON
1.00 PT-035X1/4X12 FUEL OVERFLOW TUBE
1.00 VA-102 FUEL PRES. HOSE 15.5
1.00 VA-168 SENDER MOUNT
1.00 VA-133 OIL PRESS. HOSE 27.25
1.00 VA-134 OIL COOLER HOSE 19.0
1.00 VA-135 OIL COOLER HOSE 16.5
1.00 VENT DL-03 2" ALUM FLANGE
1.00 VENT SCAT 2X6' SCAT TUBE X 6 FT
1.00 VENT TG-10 CABIN HEAT SELECTOR
1.00 DOC FWF COMPLETE TEXT/DWGS
1.00 CT BEARING HWR, CARB BOLT, NUT, WASHERS
1.00 CT BEARING HWR, PROP BOLT, NUT, WASHERS
1.00 BAG 312 AN426AD4-6 (0.01#)
1.00 BAG 604-1 FF MISC. HDWRE
1.00 BAG 607 FF MISC. HDWRE
1.00 BAG 608 FF MISC. HDWRE
1.00 BAG 611 FF MISC. HDWRE
1.00 BAG 613-1 FF MISC. HARDWARE
1.00 BAG 958 AN426AD3-4 RIVETS
1.00 BAG 991 AN426AD3-3.5
1.00 BAG 1907 AN426AD4-7
1.00 BAG 1916 AN426AD3-4.5
1.00 BAG 1934 AN426AD3-5
1.00 BAG 1935 AN426AD3-6
1.00 BAG 1978 AN470AD4-5
1.00 VA-138 FUEL SUPPLY HOSE 14.0
1.00 VA-129 FUEL SUPPLY HOSE 15.5
1.00 CT BLK THROTTLE 44.5 6(ALL)/7(360)/9(320)
1.00 CT RED VMIXTURE 45 7(360)/9(320)
1.00 FAB-360/540 FLTRD A/BOX-360 FI320
1.00 BAF-360 BAFFLE KIT
1.00 VA-149-360-PC KIT THRTLE/MIX BRCKT/360
1.00 CT BLUE VPROP 48 7(ALL)/9(ALL)
1.00 VA-183-PC MT GOV CABLE BRACKET
1.00 PROP GOV MT P-860-4 (I)O-320/360 LYCOMING
Any help would be GREATLY appreciated. Thanks.
- Matt
02-11-2008, 05:37 PM
Matt-
I just email Van's about this the other week. This is what they told me to DELETE:
And they told me to add:
CT RED VMIXTURE 47
VA-182-PC KIT
AN833-6D
AN924-6D
AN SPACER 6D
Also, you will need the Airflow performance high pressure fuel pump and filter (it's a kit on their website). Consider not using their gascolator (do some searches on these forums for not needing a gascolator with FI)
Good luck, and I am looking forward to what other people have to input on this FWF package.
02-11-2008, 08:45 PM
Matt,
I got the same list from Gus Funnell at Vans on January 21. Just unpacked stuff over the weekend, so I don't know yet whether I will end up going to the store for more parts, but it seems that most everything is there (except the boost pump, which is ordered separately). You probably don't need the gascolator or doubler.
greg
Greg Arehart
N 7965A
02-12-2008, 05:35 AM
FWF kit
Matt,
I didn't notice the wiring harness on your list? It came with my kit. I recommend using the raw wiring harness kit vs completed harness. It'll save you 100 bucks or so. It comes with all the same wires, connectors, splices etc just not put together. If you use the deluxe wiring kit you'll end up cutting and splicing anyway.
Charlie, RV-7 Tucson AZ
02-12-2008, 07:19 AM
When I ordered my FWF kit last month they told me they'd dropped the electrical wiring subkit from the kit. Suited me, as I've already wired behind the firewall and the FWF components aren't that much. They did send the master relays. I asked for the drawings, though. I wish I'd had them for the build so that I could have routed things through the bulkheads before skinning the fuselage; it would've been much easier. I also planned to have my fuel pump on the left side, per the 6A plans, but I like the down the center method in the FWF kit ... just wish I'd had that plan set and parts before I installed the center console. By the way, the answers you get seem to vary depending on who answers the phone. My paperwork is at the hangar so I don't remember who I talked to, but we changed out the throttle bracket and deleted the prop and mixture cables - I'll order those when I measure the length. I also didn't order the RV-6A subkit; apparently it wasn't necessary for my planned electrical installation. The guy I talked to seemed very knowledgeable about the XP-IO-360 and mentioned there were a couple w/vertical induction on site; we'll see how accurate he was once I receive my engine and begin the install...
02-12-2008, 08:36 AM
When you said you "asked for the drawings" are you referring to specific drawings for the wiring harness? or the standard FWF drawings? or are they one and the same?
- Matt
02-12-2008, 08:43 AM
Just a reminder. I you are deviating at all on systems, exhaust throttle quads, and such. It is best to just order what you need from the list, remember vans charges you for deletions. I bought my exhaust straight from veterman and got the mufflers, I bought the throttle quad from wicks, individually bought what I needed from vans on everything else. From what I can figure the total is coming out less than buying the ff as a whole.
02-12-2008, 12:35 PM
I would agree with allbee on the cost. I did a spreadsheet and ordering individual parts looks to be cheaper than the kit. However, the bagged hardware parts (rivets etc.) are not easily priced since there is not a list of what is in each "bag", but certainly those parts don't add up to the several hundred dollar difference. The downside is that you have to figure out what comes in those bags and then get it elsewhere, meaning time and extra shipping. I finally decided that I would just get the kit and pay the extra $ for the convenience.
greg
Greg Arehart
N 7965A
02-12-2008, 03:28 PM
Check here
Go to my website http://home.comcast.net/~n70ge and click on the Firewall Forward link. I detail a lot of the stuff that doesn't work when using the O-360 FF kit on a vertical IO-360 engine.
You'll get some extra hardware that you won't use in some of the bags as well.
02-13-2008, 05:35 PM
- Matt
I don't know. I got 8.5" x 11" electrical diagrams and rolled plansheets showing the location of actual components and wiring routing throughout the airframe. I'm assuming it's the drawings for the electrical harness as separate from the FWF drawings.
