Old 02-10-2008, 03:11 PM
macrafic's Avatar
macrafic macrafic is offline
Unhappy The Most Stupid Thing I've Done
A while back, there was a thread where people could post their most stupid mistakes. Well, I'm late, but I have a stupid mistake to add, and would like opinions.
I was installing the static ports into the F-773 side skins (SafeAir ports). The 1st one went in nicely. The 2nd one, however, is where I went on autopilot when I shouldn't have. Of course, everything is turned around from the plans, which only show one side. As such, I ended up drilling for a static port near the bottom of the skin instead of the top.
Well, I proceeded to install the port correctly, but am left with a 1/4" hole, surrounded by 4 rivet holes. The first solution that came to mind was to use the 4 rivet holes to install a backing plate. This would take care of 4 of the 5 holes, leaving just the 1/4" hole in the middle. However, with the backing plate in there, I could fill this with the appropriate "bondo" material before painting, or even fill it now.
For those of you with more body experience than I have, does this sound like a reasonable approach?
- Feeling foolish in Minnesota!
Rich and Cindy Macrafic
Rochester, MN
Flying
Old 02-10-2008, 03:19 PM
Sam Buchanan's Avatar
been here awhile
Sounds like a plan, Rich. If that is the most stupid thing you've done thus far, you are a better builder than a lot of us!
I usually don't recommend hiding rivets with filler but this is one instance where I think it would be fine and the uh-oh would be known only to you (and your thousands of friends on this forum).
Sam Buchanan
RV-6
Fokker D.VII replica
Old 02-10-2008, 04:19 PM
mannanj's Avatar
mannanj mannanj is offline
Default Back Up Plate.
You could also cut a 1/4in. circle of alluminum and rivet it to the back up plate. That would fill the big hole when you rivet the whole thing on where the 4 existing holes are. It'll look like it belongs there.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 02-10-2008, 04:57 PM
N941WR's Avatar
N941WR N941WR is offline
You could always surfact mount them like I did. Click here for pictures.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-10-2008, 05:22 PM
Jeff R's Avatar
Jeff R Jeff R is offline
Man, I wish something like that was the stupidist thing I had ever done. And I haven't even got to the static ports yet.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 02-11-2008, 10:35 AM
grantcarruthers's Avatar
grantcarruthers grantcarruthers is offline
If you go with the backing plate and fill to conceal the booboo I'd countersink the rivets, rather than dimple, and oversink them a few extra thousandths. That way they will lie deep to the skin surface and have a space left on top to fill over without leaving a high spot on the skin.
Just a thought
RV-8, Both wings with top skins on
-4 bought flying
Old 02-11-2008, 11:37 AM
macrafic's Avatar
Thanks for the responses people! I have one more question and one comment.
Question: - What kind of filler would work best for a 1/4" hole that is .025" deep? I would like something that will not shrink/crack over time, will adhere extremely well, and can be sanded/painted.
I got a response from Van's on this mistake and they made a comment that I found very interesting, considering the number of posts that exist in this forum on static port location. Their comment was
"Should work. If it's just a matter of putting (the port) in front of the wrong bulkhead, we've found thru experience that either the 707 or 708 bulkhead works."
Rochester, MN
Flying
Old 02-11-2008, 11:53 AM
az_gila's Avatar
az_gila az_gila is offline
Smile Small head rivets
Using the smaller head NAS1097 -3 size rivets in a countersink might also give a cleaner look...
I have found that they tend to fill the countersink better and give a smoother finish - perhaps related to the very slight "bulge" they have on the head?
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-11-2008, 05:39 PM
joeboisselle joeboisselle is offline
For a quick no nonsence filler for small spots like that, I usually dab a little "JB quick." Sandable and paintable.
Joe Boisselle
2010 RV-4
1941 Luscombe 8C
