Old 02-10-2008, 01:55 PM
avi8tor50 avi8tor50 is offline
Default Bending Fuel tank attach bracket
Hey all-
Got the wing mounted on right side and trying to fit the fuel tank attach bracket. I understand the need to bend the flange of the bracket a little but I have tried EVERYTHING and cannot get the thick aluminum angle metal to bend even a little! Would appreciate any thoughts. How did you all bend that thick aluminum angle? I have tried in a vice and wacking it in many different ways without any success.
As always, thanks for your help!
Peter K
9A QB
Old 02-10-2008, 02:03 PM
Mel's Avatar
Mel Mel is offline
Default Bend before cutting!
The trick is to bend it before you cut it. The full size angle is much easier bent.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-10-2008, 11:17 PM
SteinAir SteinAir is offline
Get a bigger hammer or a bigger vice, or both!
I've whacked (I mean gently bent) a number of them.....
Stein
Old 02-11-2008, 05:35 AM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Default Thick Aluminum?
Originally Posted by avi8tor50 View Post
Hey all-
Peter K
9A QB
Peter,
The thick aluminum angle is attached to the tank.
I don't think you'll bend it without deforming the tank.
The fuselage has a bracket made of steel, which is thinnner but strong too.
I'm not to that point yet, but I intend to bend the steel bracket to mate up with the thick aluminum bracket on the tank.
This may involve removing the steel bracket from the fuselage and using a vise and big hammer.
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
Old 02-11-2008, 06:47 AM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
Originally Posted by Mark Burns View Post
Peter,
....Mark
Mark, the RV-7 has steel tank brackets on the fuse. For the RV-9, you need to make your own out of thick aluminum angle, and give it a few degrees bend. Don't know why the steel bracked was not chosen for the RV-9 as well.
Peter, I precut my angle, and bent it on a vise, holding the shorter end in the vise. Then whacked it with a rubber mallet, and measured the angle after a couple of whacks. Like someone said earlier, you may need a bigger hammer or bigger vise.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
Old 02-11-2008, 08:18 AM
Mark Burns's Avatar
Oh, I assumed they were the same.
Mark
Mark Burns
Ruston, Louisiana
FFI FL-24
A&P
Old 02-11-2008, 02:32 PM
I have tried all that and have gotten no results. I believe I will find someone who has a bending brake and see if that will work. Thanks for your responses.
Peter K
9A QB
Old 02-11-2008, 02:44 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Put both edges of the angle in the vise with the vertex pointed up. Tighten down on the the vise to pull the edges closer to each other. Every few turns pull the angle out to measure it against the fuse and tank bracket. Worked for me.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 02-11-2008, 05:57 PM
mikehoover's Avatar
mikehoover mikehoover is offline
Default Beat the heck out of it
Here is a picture of how I bent mine. I had to beat the heck out of it the get it to bend, but I didn't bend them until fitting it in place. Bang it, trial fit, bang some more, etc, until you get a nice fit against the fuse.
Angle in the vice set up, ready to beat it:
http://www.aclog.com/rv-9a/images/Fu...5_DSC_0100.JPG
Nice fit against the fuse:
http://www.aclog.com/rv-9a/images/Fu...5_DSC_0102.JPG
My journal entry about this:
http://www.aclog.com/rv-9a/index.php?c=3#862
Have fun!
Mike Hoover
Columbia, SC
www.eaa242.org/
N194MH first flight on 08-26-12
Old 02-11-2008, 09:29 PM
Peter K
9A QB
No-No don't do that!!! We have a pretty good sized finger brake, but putting that short of a piece of that thich aluminum in the brake will likely "break" the brake (or deform it). I'd kill someone if they tried to do that on my brake, and it's rated for .100!
One might not notice it, but putting small pieces of material rated for much thicker than the brake can bend/twist/warp parts of the brake and should be avoided entirely.
The vice/hammer method has worked for decades on these things...just get good and mad at the darned thign - don't be gentle! Not often you really get to hit something hard on these kits!
Stein
