Old 02-10-2008, 07:14 AM
rv9aviator rv9aviator is offline
Default Compressor problem
My air compressor is blowing a pop off valve right at the compressor head. It is a 75 PSI valve. It only blows when the compressor is running. The pop off valve on the tank does not blow and is a 175 PSI valve. I'm not even sure what the 75 PSI valve is protecting. This is a two stage compressor. I started to switch the valve with another one I had but decided not to since it is a 175 PSI valve. Any Suggestions?
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 02-10-2008, 07:50 AM
captainron's Avatar
captainron captainron is offline
Perhaps a reed valve stuck open or damaged that's allowing the second stage to blow-off (backfeed) the first stage pop-off valve?
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
Old 02-10-2008, 08:48 AM
I think you're exactly right. After thinking about it I figured there must be a check valve or reed valve between the two stages. I'll pull the head and see what blew.
Jim Wright
Old 02-11-2008, 10:55 AM
airguy's Avatar
airguy airguy is offline
Three possibilities, listed here in order of likelihood.
1 - the spring in the popoff valve has weakened with time and it's blowing at less than 75 - confirm with a pressure gauge in place of the valve.
2 - Checkvalve on the second stage (either input or output) is dropping the efficiency of the second stage and causing the air to "back up" in the first stage cooling loop. Usually this is just a remove/clean/replace type operation.
3 - The second stage piston/liner is shot and not compressing at all, turning your compressor into a single stage unit - same symptoms as #2, pull the head and rotate the crank to move the piston to the bottom of the liner, check the liner with a good light. If the wrist pin or rings are trashed you'll know it immediately, it should be a smooth mirror finish.
Old 02-11-2008, 05:49 PM
Problem solved! The gasket went south and a piece of it stuck under one of the reed valves. I am ordering new gaskets but bought a new pump to get back in operation. A machine shop doesn't run without air.
Jim Wright
