02-09-2008, 05:00 PM
Lancair ES crash
I been following this since Yesterday morning when it happened.
http://blog.oregonlive.com/breakingn...any_kills.html
Quite a bit of conjecture here but
From the photos (no scrapes on the ground) it looked like it spun in. I do know the Columbia 4 place is not recoverable from a developed spin...It was IFR all around here when this happened so my guess is that somehow the pilot got disoriented and maybe stalled,spun and was unable to recover.
That would be tough to do in IMC I guess the only indication would be the ball skided off to the right.
Frank
02-09-2008, 06:32 PM
That's just what I've been thinking. It just wasn't a good day for flying.
02-09-2008, 06:39 PM
The Columbia design incorporated features to allow it to meet the spin resistant criteria in FAR 23.221. If an aircraft is shown to be spin resistant, then there is no requirement to show that it can recover from a spin. See FAR 23.221:
(2) At the applicant's option, the airplane may be demonstrated to be spin resistant by the following:
(i) During the stall maneuver contained in ?23.201, the pitch control must be pulled back and held against the stop. Then, using ailerons and rudders in the proper direction, it must be possible to maintain wings-level flight within 15 degrees of bank and to roll the airplane from a 30 degree bank in one direction to a 30 degree bank in the other direction;
(ii) Reduce the airplane speed using pitch control at a rate of approximately one knot per second until the pitch control reaches the stop; then, with the pitch control pulled back and held against the stop, apply full rudder control in a manner to promote spin entry for a period of seven seconds or through a 360 degree heading change, whichever occurs first. If the 360 degree heading change is reached first, it must have taken no fewer than four seconds. This maneuver must be performed first with the ailerons in the neutral position, and then with the ailerons deflected opposite the direction of turn in the most adverse manner. Power and airplane configuration must be set in accordance with ?23.201(e) without change during the maneuver. At the end of seven seconds or a 360 degree heading change, the airplane must respond immediately and normally to primary flight controls applied to regain coordinated, unstalled flight without reversal of control effect and without exceeding the temporary control forces specified by ?23.143(c); and
(iii) Compliance with ??23.201 and 23.203 must be demonstrated with the airplane in uncoordinated flight, corresponding to one ball width displacement on a slip-skid indicator, unless one ball width displacement cannot be obtained with full rudder, in which case the demonstration must be with full rudder applied.
The type of design changes required to meet spin resistant criteria (e.g. limit rudder authority) may make it more difficult to recover from a spin, if you are unlucky enough to get in one.
Given the design changes from the Lancair ES to the Columbia, the spin recover characteristics of the Columbia are not relevant to a discussion of the Lancair ES.
02-09-2008, 09:40 PM
I know nothing about plane crashes, but the actual plane looks to be in pretty fair shape for crashing from a spin, and or disappearing from 13000 feet. The fues, tail and wings arent in that bad a shape. Odd, what a sad day. We all work so hard and enjoy the ride.....sad to see fellow pilots/builders fall. Thoughts and prayers to thier families.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
02-10-2008, 01:30 AM
That's a sobering photograph.
Do any of you in Oregon recall what the freeze level and type of moisture was? I'm wondering if icing didn't play a larger part in the accident as he was racing to climb out of it.
Reason: Typo
02-10-2008, 07:47 AM
Originally Posted by RickWoodall
... but the actual plane looks to be in pretty fair shape for crashing from a spin....sad to see fellow pilots/builders fall. Thoughts and prayers to thier families.
Huh...
The tail cone was broken off, the wings were both snapped forward and off, the engine was canted to the right and the top was ripped off. The only reason all the parts are there in one neat pile is because it went straight in.
Most accidents happen at a glancing blow to the earth, thus parts are scattered all over the county.
The truth of it is, no plane would survive that kind of impact.
Ditto on the prayers to their families.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
02-10-2008, 07:56 AM
Originally Posted by N941WR
Huh...
And generally, the downhill velocity of a spin (if it was a spin), is much less than a dive, or spiral dive.
L.Adamson
02-10-2008, 08:00 AM
Frank
If the T&B was on the left side of the panel the ball would be left in a spin, doesn't matter if the plane was spinning left or right.
02-10-2008, 08:08 AM
Mike is right
Many years ago there was a test done on, I believe it was a Robyn aerobatic aircraft. They placed turn & bank instruments on both sides of the instrument panel. In a spin, the balls always went to the outboard side of the aircraft regardless of the spin direction.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
02-10-2008, 08:26 AM
Flat Spin
We had a similar crash here in AZ with a Lancair 360. The pictures were very similar. The witnesses of the 360 crash said the plane was very flat as it was coming down as the demonstrated with a model. They were low on fuel, aft CG with two heavy people and were doing wingovers when the engine failed. Only 6 gallons were found in the inboard wing.
This crash appears to also be a flat spin. Not sure how they would get in that if they still had power. Doesn't matter really. Very sad.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
