Old 02-09-2008, 08:30 AM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default AOA flap switch pics, anyone?
I am going to install my AOA flap switch soon and wondered if anyone has a pic of how they located it in a 7a
Old 02-09-2008, 08:40 AM
groucho's Avatar
groucho groucho is offline
Maybe these:
http://bowenaero.com/mt/mt-search.cg...IncludeBlogs=1 (RV-8)
http://www.advanced-flight-systems.c...cf038459296c87 (unknown airplane)
Old 02-09-2008, 09:54 AM
Jekyll Jekyll is offline
Made a bracket:
And installed it on the side behind the baggage side panel:
Top view:
Jekyll
7A, AoA Sport
Old 02-09-2008, 10:08 AM
AltonD's Avatar
AltonD AltonD is offline
with the AFS-3500, you don't need a flap switch. You need a position sensor, POS-12. Here is a thread showing my installation.
http://www.vansairforce.com/communit...ad.php?t=26369
also
http://www.advanced-flight-systems.c...opic.php?t=164
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 02-09-2008, 10:53 AM
Rick_A's Avatar
Rick_A Rick_A is offline
Default kept it simple
I don't have a pic handy but mine couldn't get any simpler. I just screwed the flap switch to the flap system cover (the large triangular cover) and put an adel clamp on the fore/aft actuator arm (the arm the connects to the motor).
The adel clamp just clears the cover and the screw tab on adel clamp itself opens and closes the switch.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 02-09-2008, 12:26 PM
MNRVFlyer MNRVFlyer is offline
also
The AoA kit comes with a switch. I think you are referring to a flap position indicator, not the switch that lets the AoA know if the flaps are down. Two different things.
Old 02-09-2008, 02:01 PM
Default AOA not flap position sensor
I am looking for info on the switch for the AOA. It needs to detect the flap position after 1/3 travel. Just not sure how to place the swictc that remains open or closed for 1/3 of the travel then changes...That's the problem.
Old 02-09-2008, 02:23 PM
AltonD's Avatar
Andrew, according to your tag line, you are using a AFS-3500. Look at the manual for the AFS, page 14. The sensor can be used in place of the flap switch. There is a setting on the calibration page to tell the AOA to use the sensor. I am assuming that you are using the built in AOA in the 3500. I have this setup on mine. I lower the flaps and the little donut does what is is supposed to.
http://www.advanced-flight-systems.c...ual%20V5.3.pdf
Alton DeWeese
N4IDH
Construction Log
?Mark Twain
Old 02-09-2008, 03:24 PM
Default AltonD is a genius
Thanks, wow that saves a ton of work. I've got to learn to read the manuals. Obviously this "reading the manual" thing is good! The local EAA crowd and my Dad always tease me about not reading the manuals. I will have to keep this episode a secret! Don't tell anyone.
THANKS!!!
