Old 02-07-2008, 05:26 AM
rwarre rwarre is offline
Cool tank attach angle
DUH???? I started on the tank attach angle and figured that I would have to be a artist to get the design the way the picture looked. Then it darned on me that all I had to do was copy the picture and enlarge it. That said, it worked like a charm. The part is exactly like the picture although it may not need to be so specific. Hope this helps other builders.
Empannage finished, working on wings
Old 02-07-2008, 05:47 AM
mikehoover's Avatar
mikehoover mikehoover is offline
Default Cut the pattern out
I just cut the shape out of the drawing and traced it on the aluminum angle.
http://www.aclog.com/rv-9a/images/Wing/DCP_0256.JPG
Finished:
http://www.aclog.com/rv-9a/images/Wing/DCP_0264.JPG
Mike Hoover
Columbia, SC
www.eaa242.org/
N194MH first flight on 08-26-12
Old 02-07-2008, 06:23 AM
jdmunzell jdmunzell is offline
Default Great timing of post!
I'm working on these as we speak! I didn't blow up the picture as you did, however I simply found the centerline of the 2 1/2" side. I then took a compass w/pencil in it and scribed a circular area where the radius needs to be. I then used some other drafting plastic curves and drew a line down to the edges. The result looks plenty close enough for my satisfaction!
For the 2" side that conforms to the inside of the rib, I simply took a piece of paper and pressed it down into the creases of the rib and scribed along the paper with a pencil along the rib flange to get an exact replica of the shape that needs to be transferred to the alum. angle. I also scribed along the bottm of the paper down 2" from the tip of the rib scribe line. I was then able to cut it all out and transfer the pattern directly onto the angle.
BTW, my cheapo bandsaw w/ metal cutting blade cut it all out like a hot knife through butter!
Jeff
-8 wings, finishing up
-8 QB Fuse just arrived!!!
Old 02-07-2008, 01:52 PM
tmbg's Avatar
tmbg tmbg is offline
I just used one of the inside reinforcement plates that already has that shape as a template to trace on the angle for the nose rib side. For the fuselage side, I measured the radius, drew a semicircle, then drew the lines tangent to the circle from each corner.
Ian
Old 02-08-2008, 03:53 AM
Pirkka Pirkka is offline
Originally Posted by tmbg View Post
I just used one of the inside reinforcement plates that already has that shape as a template...
I second that.
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
