Old 02-06-2008, 10:42 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Question Rivet 3 layers, Dimple?
I am doing the rudder, in the area where the skin, lower rib and faring support strips go. I am thinking of dimpling all 3 layers, as opposed to dimple king, CS middle layer and leaving the R-716 faring strip flat. My thought is without a dimple the fairing strip will be flat and not as secure as a dimple. Any thought.
here are the part numbers; Bottom of rudder, where skin attaches to R-704 rib with R-716 strips on the inside. The R-716 strips are there so the lower rudder fairing has a place to attach to. There is another 3 layer area at the upper spar, where the skin upper rib and R-713 strip come together.
Just want some reassurance that a triple dimple is OK here.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 02-07-2008, 06:19 AM
bullojm1's Avatar
bullojm1 bullojm1 is offline
Mike-
No problem with the triple dimple at all. Just wait until you get to the fuselage where there are a couple of quintuple layers that all get dimpled! The rule of thumb is to always dimple when you can. It leads to a stronger joint because no material is removed.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 02-07-2008, 07:14 AM
DaX's Avatar
DaX DaX is offline
I triple dimpled here.
http://flyingtodhunter.livejournal.com
RV-7 Wings, Tail, & Tools FOR SALE
Old 02-07-2008, 07:54 AM
airguy's Avatar
airguy airguy is offline
Same here.
Old 02-07-2008, 11:41 AM
RVG8tor's Avatar
Awesome, thanks to everyone. Isn't it weird how some of the simplest things stall the build. I figured it would be OK but I could not find the issue in the AC 43 so I thought I would ask, of course I might have missed it, nice government publication with no index meant I had to skim the chapters. Anyway thanks again.
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 02-10-2008, 09:43 AM
osxuser's Avatar
osxuser osxuser is offline
In that area I don't think the middle layer is even deep enough to effectively coutersink. In any event, I triple dimpled as well... build on!
RV4 wing in Jig @ KPOC
RV7 emp built
Old 02-10-2008, 10:08 AM
az_gila's Avatar
az_gila az_gila is offline
Smile FAA On-Line...
The index is in this link....
http://rgl.faa.gov/Regulatory_and_Gu...E/CONTENTS.pdf
...and each of the chapters can be seen here....
http://rgl.faa.gov/Regulatory_and_Gu...E?OpenDocument
...hoping these long, ugly URLs work...
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-10-2008, 11:00 AM
RVG8tor's Avatar
gil A
Gil,
Thanks for shooting me the link to the "Table of Contents" but what alluding to was the lack of an "Index". An Index allows you to look for a key word and it tells you on what pages that term appears. It usually appears at the end of the entire publication. It is convenient for finding specific information. In my years in the AF I find that many government documents lack an index, not sure why they just do. Thanks for you effort.
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 02-10-2008, 11:06 AM
az_gila's Avatar
Default Ooops...
Gil,
You are correct... I messed up "Index" and "Table of Contents"...
I do have a version around of the AC that I indexed with Adobe Acrobat. It allows word searches of the whole document... not quite an index, but still useful. Unfortuneatly, it's the old version so I don't want to release it.
We need some bored at work with a copy of the full Adobe Acrobat to do the same thing to the latest version....
gil A
Gil Alexander
Old 02-10-2008, 03:58 PM
RVG8tor's Avatar
Default Soft copy
gil A
Gil,
I will definitely be using the links you posted with the Adobe files. Word search with the computer is better than an index. I just never looked for AC-43 online. I have been working with a paper copy I bought from an online book store. Thanks again for your help, this is not the first time you have pointed out good online resources keep them coming.
Cheers
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
