Old 08-01-2005, 08:25 PM
jim jim is offline
Default Want to go to Land of Enchantment
Hi,
I have been lurking here for quite some time now and on the matronics site for years. I have a flying RV6 (purchased) and have been working on a 8 for far too long. I want to go to Land of Enchantment this year. I live in Michigan, but, I have absolutely ZERO experience with mountain flying. I am looking for advice as far as route, and questioning whether it may be feasible to hook up with other RVers planning to go so as to not attempt this alone for my first mountain experience.
I picked up Sparky Imesons book Mountain Flying at OSH this year, also got a O2 tank and cannulas for the plane. I plan on having a passenger with me for the entire trip (unless she who controls all decides not to go).
I have visited the LOE site and read the various write-ups available and would really like to make the trip, I am just worried about the mountains and my lack of mountain experience.
From what I have seen I think it would be best to fly to TX, maybe DFW area, then hang a right and head west from there? I am looking for suggestions and advice and possibly hooking up with others planning on making the trip who wouldn't mind a tag along.
Jim
RV6 flying
RV8 wings (still)
Old 08-01-2005, 08:35 PM
unqualified unfluencer
Hey Jim,
Swing down to western Texas and go *just* south of El Capitan (Guadalupe mtns). It's pretty flat there and the view off your right wing will be incredible: http://www.vansairforce.net/loe/loe4_pics/IMG_2176.jpg.
El Paso is just west of that and it's flat through the passes - lots of long flat roads. I would call it 'desert' flying before I'd call it 'mountain'. On the day of the fly-in listen on 122.75 and you'll probably be able to join in a long string of Texans headed that way <g>.
Hope to see you there!!!
Best,
Doug Reeves (your host)
Old 08-01-2005, 08:51 PM
jim jim is offline
Hi Doug,
Thanks for the reply. I need to get some sectionals and start checking out the trip. Will definitely listen in for the line of Texans!!!
Jim
Old 08-02-2005, 06:20 AM
mrreddick mrreddick is offline
Super Moderator
Location: Hangar/home at Hicks Airfield (T67), Fort Worth, TX
We are on the RV Hotel list and are located right across the taxiway from Jay Pratt's RV Central. The hangar owner directly across from us is currently building a 10 with Jay.
If you want to break up your trip come on down and meet the BC Squadron guys and fly out the next morning.
Mike Reddick
VAF#153
Pilots N Paws Pilot
RV6A N167CW 1,900 HRS
Ft Worth, TX (T67)
Old 08-02-2005, 07:50 AM
Default When you plan
As Doug says, the mountains are not a real big thing in that part of the country. Just plan with lots of fuel reserve; the head winds can be severe and the refueling options are far between. Also there are some serious Restricted areas to be avoided.
Bob Axsom
Old 08-02-2005, 09:49 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default WHere are you going park
Airports near Anaheim
Chino* (The Air Museum ~ Planes of Fame)
Corona*
Riverside* (RV hotel list?)
Fullerton**
Compton
Longbeach
* Out side LAX Class-B and 20-30 miles East of Disneyland
**Closest to Disneyland (never been there)
Flying over / around the Rockies is not a big deal, but consider going around and doing an end-run thru Albuquerque NM. This adds only 100 sm and brings you over much lower terrain and cruise altitudes. It is still high (desert) but not near the 12,000' peeks like the ones near Denver. Going direct takes you by Denver and some real high hills.
Going a little further south, thru ABQ also puts you by Las Vegas, NV or Phoenix, AZ. You may want to consider a RON at one of these cities if you are so inclined on the way out or back.
As far as headwinds, I think your mountain flying book will warn you about winds aloft greater than 20kts over the mountain tops can be bad news (turbulence and vertical up/down drafts which can exceed aircraft performance).
From what you say you plane on flying high with O2. I am all for direct routes and mountains, which don't bother me too much. I flew freight years ago in old twins over the Cascade Mountains in the winter. Still you may want to consider the southern route with lower terrain and more available airports.
I think of real Mountain flying low thru the passes well below the surrounding peaks. It is fun to do, but snaking thru a mountain pass following a road is not a fast way to travel. Also taking a wrong turn into a blind canyon has bit more than a few pilots. Even with the RV's great performance, at high altitudes, hot temps and heavy weight you can get into a situation where you are sucking wind and can't out climb the rocks. Getting into a narrow pass may not give you room to turn around. Ouch.
The restricted areas east of LA basin (especially R2501 Bullion mountain) needs to be avoided, altitude is surface to unlimited, but with GPS that should be a snap. No worries there, but there are some that pop-up enroute and the GPS is a real help. I know my GPS alerts has saved me one airspace incursion. Best advice is have fun, fly safe. It really is no big deal. ONe great peice of advise is gas prices. Go the AirNav and use the fuel planner to calculate a route based on gas prices. National Gas avg cost is $3.27 to a max of $5.25, this could save you some cash so you can buy those Mouse ear hats you want. You can still find gas for $2.20. You can save about $42 on this trip each way.
http://www.airnav.com/plan/fuel/
Cheers George
Whoops, Wrong land of enchantment
Old 08-02-2005, 10:56 AM
Default I think you have the wrong LOE
I think the thread starter is interested in going to the desolate part of New Mexico west of El Paso not the real enchanted part up the valley north of ABQ and certainly no LA. Planning will probably involve refueling at Midland. 14 years ago when returning to LA from the AOPA Convention at New Orleans I was on a leg from Kileen to Ft. Stockton and with some conservative inflight calculations I was sure I could make El Paso. The headwinds came up over 60 kts and there is no way I could make it even though I could see the mountains west of El Paso in the distance. I saw a paved strip in the middle of nowhere that was not on the charts and told El Paso Approach I was going to have to land there. It was a private ranch strip and the the lady that was there did have some avgas that she sold me. She said this happens all the time when the winds come up and the previous year at couple in a bonaza made a pass and circled back to land but crashed short of the runway. When I climbed out the same controller was on duty but I was not inclined to contact anyone. I did very discretely call however, and the cheerful old hand controller said "welcome back 04Lima..." Since then I pay great respect to that part of the country. The restricted areas include the White Sands Missile Range. When we flew by there in March two B-52s were making runs on the place. It is an adventure to treasure but plan well and be careful.
Bob Axsom
Old 08-02-2005, 12:38 PM
Super Moderator
Default Re: Want to go to Land Of Enchantment
Bob & others,
In regards to fuel in Texas, Bridgeport Municipal (XBP) is located about 26 nm northwest of the DFW metroplex and currently has fuel for $2.53 (recent high was 2.65). It's self-service 24/7 and has a very nice new terminal and very clean bathrooms.
The group I flew out with to LOE last year stopped at Andrews County Airport (E11) at Andrews, TX, located north of the Midland/Odessa mess. The current fuel price there is $2.62 and it's a big self-service ramp. Others we knew coming out from south of DFW stopped at Winston Field (SNK) at Snyder, TX. Current fuel price there is $2.95.
Study those charts and hope the info helps. The other big restricted area that I can think of for someone coming from Michigan would be the Lawton, OK, Fort Sill area. There's a pretty big one there that you don't want to stray into.
Bob mentioned seeing B-52's making a run over White Sands last year. Just as we came around El Capitan for some photos we were able to see White Sands to the north. Just as I called my wife's attention to it they shot a missile up. What a sight! What a welcome!
Hope to see all of ya'll out there this year!
Mike Reddick
VAF#153
Pilots N Paws Pilot
Ft Worth, TX (T67)
Old 08-02-2005, 08:56 PM
jim jim is offline
Mike, Bob, and George,
Thanks for the replys guys! I will order the charts this week and begin planning for this trip. All of my flying to date has been in the midwest and while we have some beautiful sites I can only imagine how awesome this trip is going to be.
Mike, I appreciate the invite and may just do that if it isn't a problem for you. Are there many people from Hicks planning on making the trip? It sure would be nice to follow along with a group . I have been trying to look back through the site to check out the reference to the BC Squadron but haven't found it yet. Forgive my ignorance here, and please no disrespect intended, but can you tell me a little about this Squadron? How many RVers are located at Hicks? I have seen Jay Pratts name mentioned quite a bit on Dougs site. The nearest RV to me is about 50 miles away, not too many being built in north central lower Michigan. Sounds like your area is an RV mecca of sorts. Man, that would be nice to be closer to an active RV community.
Thanks again for the replies,
Jim
Old 08-02-2005, 09:56 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default Sparky Imeson's "Bible"
If you do get around to flying mountains, I would definitely concur with your use of Sparky Imeson's mountain flying books. I'm not sure if you have his "Mountain Flying" or "Mountain Flying Bible." If you do not have the latter, I would strongly encourage it. The former is good, but watered down. The latter is extra thorough, but could use a good editor. Neither is perfect, but I think if you really want to understand mountain flying (aside from, and in addition to, getting a good checkout from someone who knows mountain flying), the Mountain Flying Bible is a great resource that I would encourage you to pick up.
If you have a chance to fly mountains do it, even if you have to get instruction first! I just moved from Ohio where I had to live for four years. They were the four most boring flying years of my life--if there is such a thing with flying . I made it back to the mountains where I learned to fly and hope I am never without them again. Go to LOE via the Rockies (even if you have to take a detour) is my vote!
Have fun-
Steve
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
