Old 02-05-2008, 11:47 AM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Dumb question - bolt size engine case ground
I feel really dumb but I can't seem to figure out what size bolt I need. There is a threaded hole on the rear of the engine case that I want to use for the ground connection. It's sorta behind the Dip stick tube near the prop oil line. It's an ECI O-360 case.
It's appears to be a 5/16th bolt and I've tried both 18 & 24 tpi bolts and can't get either one started.
Anyone know what size bolt to use?
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 02-05-2008, 05:12 PM
TSwezey TSwezey is offline
Did you try a metric size? They have them in Home Depot in the specialty section.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 02-05-2008, 05:18 PM
szicree szicree is offline
Why in the world would one solitary hole on the entire engine be tapped metric?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 02-05-2008, 05:59 PM
Beats me? I was just offering a suggestion.
Todd
N110TD
Old 02-05-2008, 06:02 PM
I hear ya Tom, but these engine cases are pretty pricey (and soft). I'd be cautious about threading any old thing into em.
Steve Zicree
Old 02-05-2008, 06:26 PM
Mel's Avatar
Mel Mel is offline
Most all holes tapped into a casting are coarse thread. You should be able to tell by looking whether it's fine or coarse thread.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-05-2008, 06:29 PM
Radomir's Avatar
Radomir Radomir is offline
Do you have a pic of that? I can't remember anything in that area.. except the 1/4-20 hole used for the baffle.. which is directly behind the oil filler tube (it's kinda hidden by the tube)..
Radomir
RV-7A sold
Old 02-05-2008, 07:31 PM
Rick_A's Avatar
Here's a picture of the location but you can't see the hole very well because it facing aft. It the one right above were the dipstick tube is safety wired.
Here's a picture of the actual hole taken using a mirror. It can be seen between the engine mount and the oil line.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 02-05-2008, 07:58 PM
I do seem to remember that hole being a baffle mounting. Speaking of that, I get the impression from the pic that you are doing wires and plumbing before baffles. If so, you may want to reconsider. The baffles have a way of interfering with wires, hoses, etc.
Steve Zicree
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
I would recommend running a tap into the hole and back out to clean it. Use the correct size, of course. When I built my engine with an A&P I/A, I had the task of putting the valve covers on and managed to have one that wouldn't let the bolt start threading in. Simply cleaning up the threads with a tap did the trick.
I'm guessing you messed the threads up a bit by using the wrong bolt (it probably is 5/16th, but course or fine is anyone's guess). Clean it up and you should be good to go.
Sonny W
Boise, Idaho
RV-7A Flying!
