PC 680 terminal size
I just purchased a Odyssey battery from a local source (much cheaper than Vans, Spruce, or Wick's, btw) and noticed that the terminal bolts are 6mm. The terminals I got from SteinAir for 2AWG cable have 1/4" holes, which is significantly larger than 6mm. Do I need to find different terminals with 6mm holes or is a little bit of slop acceptable here?
I also understand that there is a thread adapter to go from 6mm to 3/8 SAE. However, I can't find it listed anywhere, including the Wick's site that mentions that it exists.
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
