Old 02-04-2008, 02:56 PM
macrafic's Avatar
macrafic macrafic is offline
Default ELT Mounting
I looked through the ELT mounting posts that I could find, but did not find anything along these lines. That makes me think we could have a case of "operator error" here.
I bought the bracket from Van's for mounting the ELT and have that installed. My question is about mounting the ELT itself on that bracket. To do that, I must install the bracket that came with the ELT on Van's bracket, using screws in the nutplates that I installed. However, the strap that holds the ELT on appears to go between the two brackets, thus not allowing the two brackets to fit together and leaving the mounting less than solid. I have ideas to fix this, mostly using shims but I wanted to query those who have gone before me to make sure I'm thinking correctly here. Am I missing something?
Rich and Cindy Macrafic
Rochester, MN
Flying
Old 02-04-2008, 03:09 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
I used shims, Rich, to address the issue you raise. However, I didn't use Van's bracket, but I don't think it matters.
Here's how mine ended up (last post on this thread)...
http://www.vansairforce.com/communit...t=elt+location
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
