richer carb
I agree with the 4164.....it is the richer one.
The other one is the 3878.
Pretty sure, even with the FP prop....
assuming this because of the C/S gear you have to sell....
you will benefit from the richer carb.
The 3878 can be modified to be a 4164 if you find a good deal on a used one.
Good Luck
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
