Old 02-02-2008, 04:01 PM
claycookiemonster's Avatar
claycookiemonster claycookiemonster is offline
Default Fuel Tank Final Assembly Sequence?
SO...if I do the baffle before I do the inspection plate, I can make sure the fuel pick-up isn't clogged with sealant and see a bit of the baffle seal from the inside, BUT then how do I seal the plate screws on the inside?
OR...I could do the plate before I do the baffle and just hope the pick-ups are clear?
Comments?
Clay Cookie Monster
tanks, TANKS ALOT!!!!!
N838CM reserved
Old 02-02-2008, 05:03 PM
DGlaeser DGlaeser is offline
Default Baffle first . . .
The inspection plate should go on last - after all that is it's purpose If you smear a bit of FuelLube on the screws they will seal just fine.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
