Originally Posted by Guy Prevost
That would be my guess. I drilled mine yesterday and noticed that the hole went right through a joint in the first layer of aluminum aft of the firewall. The steel and stainless steel layers are whole, of course.
Guy
Yes, on mine the steel layers sandwiching the aluminum gusset is also find. It is the aluminum gusset that cracked. I can tell they are cracks because they run longitudally, I can see the layers between the metals that I am drilling and it is not those cracks. I thought maybe it was from having a dull bit or something but it still happened on the other side when I used a step drill. The gusset, since it is sandwiched between two steel plates, is not visable and since this fuse was a quickbuild I never built that part.
- Matt
