Old 02-01-2008, 07:38 PM
N941WR's Avatar
N941WR N941WR is offline
Default I need an RV Construction History Lesson
Mel,
Over the years you have posted comments about your early -6 kit. Could you elaborate?
Things I think I've heard:
1. No holes of any kind
2. All dimples were done with a pop rivet dimpler. Didn't they have a C-frame in that cave?
3. How about the cowl? Did you have to make that too?
4. Electricity, did you have electricity?
I realize how easy us match hole kids have it but would like to learn how rough the true RV pioneers had it.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-01-2008, 07:51 PM
Mel's Avatar
Mel Mel is offline
Default Ha, Ha. Wasn't funny then.
Originally Posted by N941WR View Post
Mel,
1. No holes of any kind!
2. The "C" frame was around. Bob Avery's invention BTW.
I just used the pop rivet dimpler because I was used to it.
3. We got a cowl but it was a pretty poor example. I had to glass the upper and lower halves together with material added in between to get it to fit properly, then re cut it.
4. We had electricity, but Ann had to pedal the generator to keep the compressor going.
5. Added note. The plans ended at the firewall. The firewall and everything in front of it was up to you.
6. The wing plans were converted from -4 plans, so the fuel tank mounting holes were all screwed up. The plans and the drill plans were different and they were both wrong.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-01-2008, 07:57 PM
N941WR's Avatar
What did they do in WWII and since? Where all those planes built with pop rivet dimplers? Oh, that would have taken a long time!
She's TOUGH!
Are you saying you didn't even get an engine mount?
Bill R.
SC86 - Easley, SC
Old 02-01-2008, 07:59 PM
The kits showed up on a horse drawn wagon. You had to pay in gold bullion, diamonds, or emeralds. Sometimes they would accept Jade or Amber. You submitted questions to tech support by carrier pidgeon. The answer was always "make it fit". (Some things never change.)
We had to use these wooden fixtures called jigs to hold the parts in the correct orientation. Lots of fun with measuring tapes, plumb bobs, shims, chalk lines, and other apparatus from the stone age.
There were no pre-punched holes. Making sure you hit the centerlines of the ribs and bulkheads when you drilled holes was an excercise in measuring, marking, re-measuring, checking plumb, then drilling and hoping you hadn't screwed up somewhere. I eventually learned to pre-drill the holes in ribs and bulkheads, then back-drill the skins.
The plans were OK, but the manual went from excellent on the empennage (10 or 20 pages with pictures, diagrams, good sequences, etc.) to pitiful (I swear, the fuselage section of the manual was about 2 pages.).
The best thing about it was that RV's were far less common back then. Anywhere you went, you got compliments on your airplane and questions about how it flew, how long it took to build, etc. With the popularity of the RV's today, you just don't get as many of those experiences.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 02-01-2008, 08:03 PM
Mel's Avatar
Mel Mel is offline
Engine mount, cowling and spinner were supplied. But no plans forward of the firewall. Landing gear legs were not drilled top or bottom.
Old 02-01-2008, 08:10 PM
Geico266's Avatar
Geico266 Geico266 is offline
There is a guy on our field that has one for the first flying RV-3's. A beautiful airplane. When he looks at the "new" kits he just shakes his head.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 02-01-2008, 08:23 PM
AMURRAY's Avatar
AMURRAY AMURRAY is offline
Default Tip up only
And you had only one choice of canopy. The tip up.
RV6 built and flying
Bearhawk Patrol plans purchased
Old 02-01-2008, 10:18 PM
zilik's Avatar
zilik zilik is offline
VAF Moderator
Talking Bauxite
Mining the bauxite ore was easy. Smelting and rolling the aluminum into sheets was the hard part.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
Old 02-01-2008, 11:04 PM
yakdriver yakdriver is offline
A friend of mine got RV6 kit #7 actually #207 in the Van's numbering system in 1986. It came in flat boxes with almost no prefabrication. How he didn't cut a finger off fly cutting all those lightning holes in the ribs I'll never know. He did get one of the first Phloginston spars but otherwise it was all built by him. He finished it in 1991 and flew it for almost 10 years before selling it when he hung up flying at age 79. N number is 207DC and its still out there flying. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 02-02-2008, 06:29 AM
Mel's Avatar
Mel Mel is offline
The hardest part for me was the hours and hours sitting at the lathe turning out rivets.
