Old 02-01-2008, 04:42 PM
Paul Tuttle's Avatar
Paul Tuttle Paul Tuttle is offline
Default Canadian MDRA inspection. Bolts
A friend who is building a Sea Ray was told by the MDRA inspector that any bolts used where they will rotate ie: elevators,rudder,ailerons, control rods etc have to have castle nuts and cotter pins instead of nylocs.
Did anyone run across this with their inspector?
It doesn't make a lot of sense that nylocs work fine in the US, but are unsafe in Canada.
Paul Tuttle
RV 8
C-FPVT
Flying.
Old 02-01-2008, 04:48 PM
Mel's Avatar
Mel Mel is offline
Any bolt that is subject to rotation must be safetied. A nylock (in this situation) is not sufficient in the US either. Ref. AC43.13-1B Chapter 7 paragraph 7-64.a.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-01-2008, 05:22 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
The bolt and rod end eye are stationary and locked together. The rod end housing swivels on the eye.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 02-01-2008, 05:49 PM
Mel's Avatar
Mel Mel is offline
Ross,
The Sea Ray doesn't use rod end bearings. The hinges swivel on the bolt.
Old 02-01-2008, 05:53 PM
rv6ejguy's Avatar
Originally Posted by Mel View Post
Ross,
Ahha. Better cotter pin 'em then. Losing an elevator will spoil your landings I hear. Thanks Mel. I've had people ask me this same question on RVs.
Old 02-01-2008, 05:58 PM
Ron B. Ron B. is offline
Same MD-RA must have missed this on two SuperCubs as I just had (yesterday) an AME look over mine and he picked that out for me to replace. He said that he doubted it would ever cause a problem but it's not up to standards. I will change them to castle nuts.
Old 02-01-2008, 06:20 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Here is a good example--------I just installed the cables that hold the rear seat shoulder harnesses. Exactly same cable/clevis setup as the rudder cables.
Rudder uses castellated/cotter pin. Seat belt uses nylock.
Only difference is that the rudder is expected to have motion at the connection.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-02-2008, 09:35 AM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default I got the same information
Hi Paul, I got the same info from my MD-RA guy. He came to inspect my quick build and I already had the stick, elevator and aileron parts in and he made me change all the nuts and bolts to castle style. It only cost $10 - $15 for all the new hardware so I figured why argue. He will also get you for the vans heater box because it is made of alum instead of SS. I just changed mine.
Old 02-02-2008, 09:53 AM
rvbuilder2002's Avatar
Yea...I heard this is what is causing a lot of Cessna's to be grounded. Can you believe it, their heat box valve is made of aluminum
Scott McDaniels
Hubbard, Oregon
