Originally Posted by 1911pilot
I'm pretty sure the only parts that are common to the 9 and 7 emp are the VS Skeleton and the Rudder. (The 8 looks like it uses the VS Skeleton and same VS Stab skin as the 7.) At least that the only drawings I have in my plans for my 9 emp with multiple model numbers.
Jeff
That is true. The OLD style -7 used the -8 rudder. The NEW style uses the -9 rudder.
The -9 HS has the fat HS ribs all the way to the tip and sports a MASSIVE trim tab that is about 18" long! The -7 is similar to the -8 HS, but where it couples with the fuse... it is wider. This is due to the fact that the -7 fuse has a greater taper due to the double wide cabin.
CJ
