Old 01-28-2008, 10:35 AM
CNEJR CNEJR is offline
Default Another Stupid Question?
I am wiring my 6 using a conventional switch for the mags & starter and a split switch for the master & alternator. Question? Should you be able to engage the starter with the master off?
I know Van's system shows "no" on their basic wire diagram, but in the unlikely event you had a generator failure & low battery complicated by engine stop, wouldn't you want to turn the master off to conserve battery and still be able to crank?
Oh, these little stupid questions.
Chuck Elsey
RV6 Start 7/06- Flying!
N349CE
Old 01-28-2008, 10:43 AM
johnp johnp is offline
one has to ask -- what is going to provide the energy to turn the starter?
john prickett (VAF 449)
manchaca, tx (suburb of austin)
rv-7a finish kit
N337JP (reserved)
Old 01-28-2008, 11:04 AM
Low Battery, Not No Battery.
Chuck Elsey
N349CE
Old 01-28-2008, 11:07 AM
Jamie's Avatar
Jamie Jamie is offline
Default Possible Problems with this approach
What happens if you wire the starter solenoid directly to the battery, then the solenoid fails closed (it does happen occasionally)? How are you going to shut off the power to it?
Old 01-28-2008, 11:10 AM
Mel's Avatar
Mel Mel is offline
No! (words added to message acceptable)
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-28-2008, 11:17 AM
Thanks Mel, I read your posts & value your opinion.
Chuck Elsey
N349CE
Old 01-28-2008, 11:35 AM
Mel's Avatar
Mel Mel is offline
Sorry about being short with my previous post. Making the starter available with the master switch off is a BIG safety issue.
Why would you need the starter in flight? If the engine died, there's usually a reason and a restart would probably not be a good idea.
My starter is wired through the backside of my avionics master switch. If the master switch is off or the avionics master is on, the starter is not available.
