I found this link to a step by step procedure for using the Loctite 290 to seal rivets. Using a vacuum to draw the Loctite in was interesting. Be VERY carefully to purge the tanks of all fumes before drawing tank air into a sparking motor. Also, the Loctite 290 seals better if used in warm temps, 80F +.
I thought I would start a new thread for future use.
http://www.seqair.com/skunkworks/Mai.../TankLeak.html
