If the material isn't very thick, then you'll stretch the aluminum as the bottom edge of the hole becomes thinner. Use another piece of aluminum with a hole in it cleco'd to your part to back up the hole. Or, what I do is align the hole in the part with a #40 hole in my table and then countersink. The hole in the table helps keep the bit from wandering.
PJ Seipel
RV-10 #40032
