The colored side of the insertion/extraction tool (the one where the metal part is a half-circle) is used to insert the pin. Most of the time you can just push on the wire until it clicks, but if you've got a bunch of wires or the wires are very small, you can use the insertion tool to push the pin into the hole.
To extract, you use the other end of the tool. Get the metal part wrapped around the wire, push it into the hole as far as it will go, and then pull the whole thing out. It should come out easily; if it doesn't, you probably haven't pushed the tool into the hole far enough to get the pin to release.
PJ
RV-10 #40032
