Old 01-24-2008, 04:39 PM
ChrisL ChrisL is offline
Default Gap between Horizontal Stabilizer Tip / Elevator Counterbalence Arm
I have sized my HS / Elevator fairing gaps down to an even 3/32" and did the same on my VS / Rudder fairings. I have heard a lot of folks mention that 1/8" is the minimum for this gap, but I am wondering what I should be concerned about. Is this mainly an ice consideration? or is it more to do with flex / movement while under load.
Please feel free to comment on the pic below...
Chris
Chris Lund
Portsmouth, NH
RV-7 Emp, Wings, & Fuse Done - Working on the Canopy
Old 01-24-2008, 04:44 PM
Geico266's Avatar
Geico266 Geico266 is offline
You'll need to take the duct tape off before painting.
Seriously, I think the 1/8" - 3/32" gap is to account for paint build up later. You just don't want them to rub. Nice fit BTW.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 01-24-2008, 05:58 PM
DGlaeser DGlaeser is offline
Default Gap
The gap is mostly for ice, and maybe mud, sticks, etc. if you fly off turf.
If that area flexes enough to cause problems, you have other, bigger problems
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 01-24-2008, 06:50 PM
SMO's Avatar
SMO SMO is offline
Default How about .060?
Here is a data point for you.
I recently purchased an RV-4 where this gap at the end of the counterweight (counterweight is angled a little) is so close you would have trouble putting a piece of paper in it. If you push the counterweight a little it will actually rub against the HS. I suspect this has been this way for most if not all of the 450 hours on the airplane, although there may have been an event that caused this (there is a small dent in the trailing edge). There is no evidence of regular rubbiing in that area. I have decided to reskin this elevator and correct the angle of the counterweight in the process, but the resulting gap will still be in the neighborhood of 2/32 (a whole lot better than nearly nothing).
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 01-24-2008, 09:23 PM
DanH's Avatar
DanH DanH is offline
<<Please feel free to comment ..>>
Really nice work!
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-25-2008, 05:33 AM
Wow - I'll take a compliment from Dan Horton (Fiberglass Guru) Anyday!
Chris Lund
Portsmouth, NH
Old 01-25-2008, 10:37 AM
DanH's Avatar
Please, no guru tags. I'm just a homebuilder. Gurus can be found among the composite plans-only guys, or for me, down the street at the GKN plant.
Dan Horton
RV-8 SS
Barrett IO-390
