Old 01-22-2008, 10:55 PM
Michael Burbidge Michael Burbidge is offline
Default Prep-n-etch from Home Depot...
I found a product called prep-n-etch at Home Depot. It is a metal cleaner meant for prepping metals, including aluminum, for painting. It is phosphate based. Has anyone tried it? Would it be appropriate before priming aluminum airplane parts?
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 01-23-2008, 10:28 PM
Greg Arehart's Avatar
Not sure I can answer the real question, but if it is phosphate based, it is probably phosphoric acid, which typically will help dissolve (iron) rust. Not sure what it will do to aluminum or aluminum alloys. Partly would depend on what else is in there, based on what I know of chemistry.
greg
Greg Arehart
N 7965A
Old 01-23-2008, 11:47 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Acid...
greg
Greg.. It appears that phosphoric acid is the main active ingredient in Alumiprep 33
http://www.jamestowndistributors.com...alumprep33.doc
But why risk the Home Depot stuff? You can buy acid etch that meets aluminum acid etch/alodine requirements at your local auto paint store... and no hazardous shipping charges...
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-24-2008, 04:45 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default acid etch
Phosphuric acid is also the active chemical in Variprime to etch the metal.
Regards...Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 01-24-2008, 05:21 AM
terrykohler terrykohler is offline
You can also purchase all of the blind rivets you need at Home Depot. This will probably save you more money than the etch. Like the phosphoric acid, all you need to know is that they are aluminum. Please, unless you have a great deal more info on the paint, stick to aircraft grade material. You've invested a lot of time and money to this point. Why would you want to risk all of this work?
If you want to see the ultimate in money saving, look at the post where builders are hand threading their gear legs. After literally chiseling the thread form onto the heat treated shaft with a constantly dulling die, no one seems to care that they have likely generated a significant number of tears and cracks which may eventually lead to fracture. If the nut fits, good enough. Save money? Yup!
Terry
Old 01-24-2008, 07:13 AM
Mel's Avatar
Mel Mel is offline
Default Just to clarify..
Terry,
I assume that this comment is "tongue-in-cheek."
But before some "newby" runs out to Home Depot to buy pop rivets, let me say that any blind rivets used in aircraft NEED to meet some kind of "specification!" The ones at Home Depot don't!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-24-2008, 09:42 AM
Default Ordered Alumiprep...
Sorry for asking the question. You guys are right, it is stupid to get this kind of stuff at Home Depot, when you're not sure it will work just to save a few bucks. I couldn't find Alumiprep locally so I ordered some. That and Alodine.
Michael Burbidge
Sammamish, WA
RV-14A Empennage
Old 01-24-2008, 10:29 AM
Captain_John's Avatar
No, not necessarily so. I am sure product is product. The question is, what is the product.
Each brand is it's own "chemical soup". I can't believe there are that many soups out there to choose from.
I got the stuff from West Marine in the (2 ounce?) bottles. It APPEARS to be Aluma Prep and Alodine. It is SUPPOSED to prep and convert aluminum. It looks and feels like AP 33 and Alodine. I don't use much of it and for my needs, it should be fine.
It may suit you too?
CJ
The experiment works!
Old 01-24-2008, 01:41 PM
az_gila's Avatar
Smile Apples, apples and oranges
CJ
Captain... not quite apples to apples..
If it's this stuff from West Marine... yes it is probably the usual acid etch/alodine treatment (two steps) for aluminum.
However, the original poster was talking about some generic (try a Google search "prep-n-etch", all I came up with was a concrete etch) hardware store stuff that is for all metals, and is one step.
Not quite the same thing.
gil A
Gil Alexander
Old 01-25-2008, 09:22 AM
caryr's Avatar
caryr caryr is offline
"Wheel Brite" is a product at auto cleanup suppliers that works like the Alumprep.
makes alum shine like new money
cary
Cary Rhodes
Taylorsville, Georgia
N203CR
Van's RV-7
First Flight April 2004
