Old 01-22-2008, 04:27 PM
Randy Walls's Avatar
Randy Walls Randy Walls is offline
Default Observations from a new builder
I am about half way through the RV-7 tail kit. I thought I would post some observations.
1. Building is a LOT of work.
2. Van's replacement parts are reasonably priced and the folks on the other end of the phone are very nice and competent.
3. Before you cut, drill, or bang on anything look at the drawing 3 times and measure twice. Then do it again,(see number 2 above).
4. I have learned to hate blue plastic!
5. Building is more fun than you should be allowed to have!!!
This is so cool!
Randy Walls
Cessna 120
Old 01-22-2008, 04:42 PM
jeff beckley jeff beckley is offline
Dont forget that your friend count will diminish. They will wonder if you are in jail.
Jeff Beckley
Des Moines Iowa
Van's RV-7A
Old 01-22-2008, 05:00 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Actually your friend count should increase from RV folks.
Old 01-22-2008, 05:02 PM
jmartinez443 jmartinez443 is offline
There is a trick to dealing with blue plastic. Go to your local Radio Shack and pick up a cheap soldering iron. Round off the tip and use the hot tip to cut a nice swath for your rivet lines. Your parts will then look like this:
Jorge Martinez
QB 8A Fuse. Just battled the ^%&@ing gear weldments. Now I can move on.
http://www.rv8alog.com
Old 01-22-2008, 09:16 PM
RScott RScott is offline
Default Easy plastic removal
For larger parts, peel off a little plastic, say 2 inches from the end. Using tape of some sort, like duct tape, tape that plastic to an old broom stick, piece of PVC pipe or something similar. Take a pair of vise grips, grab on to an end of the pipe and roll the plastic up. Comes off easily.
For small parts, peel back a little plastic, grab it with your hand seamers and pull the plastic off.
Plastic comes off a tiny little bit easier if it is at room temp vs. cold.
Richard Scott
RV-9A Fuselage
1941 Interstate Cadet
Old 01-22-2008, 10:03 PM
rv6rick's Avatar
rv6rick rv6rick is offline
JOAT-MON & Moderator
1. And a LOT of fun and education.
2. 'Replacement' parts are the same parts/price as original parts....of course they're nice...they are selling parts .
3. Yes...1st rule of building 101.
4. Whenever I have a lot of plastic to remove (skins) I go get the kids and we all jump in!
5. If you think you're having fun now...wait till you get to the fiberglass
This is so cool!
Rick Gray in Ohio - Builder Assist Center - 50+ Awards & counting
BRONZE / SILVER & GOLD LINDY AWARD WINNING RV's & Rockets
EAA Oshkosh Homebuilt Judge/Tech Counselor/Flight Advisor / F.A.S.T. Formation Flight Lead
Kitfox/RV4/6/7/8/9/10/12/14?s
6 RV10's
2 Time Sun n Fun Grand Champion
F1 Rocket #1 Oshkosh Gold Lindy Grand Champion!
F1 Rocket #2 :-)
Fastback RV8 Slider
RV14 #2 in progress
53 RV's & Rockets & counting
Whirlwind Prop Dealer
Love my Pitts S-1S
Old 01-22-2008, 10:51 PM
Yes that is true! But the old ones will start to wonder what happened to you.
BTW the new RV friends are much more interesting now.
Jeff Beckley
Des Moines Iowa
Van's RV-7A
Old 01-23-2008, 07:10 PM
Robert M's Avatar
Robert M Robert M is offline
I actually heard (read) one individual talking about how therapeutic removing the blue plastic is..... One man's pleasure, another man's pain ?!?!?
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
FLYING since 2018
Mosquito XEL ready for flight
Old 01-23-2008, 09:42 PM
airguy's Avatar
airguy airguy is offline
Therapeutic? Perhaps....
Myself, I decided this evening that I'm tossing the rounded-tip soldering iron and joining the plastic-peeler club. It's just a little too much work, a little too much worry about scratching the surface with the iron, and I just decided I'm simply not anal enough to mess with it. Off with the blue plastic!
