  #11
Old 08-16-2005, 07:33 AM
jonbakerok's Avatar
jonbakerok jonbakerok is offline
Default I'd check the wiring
Originally Posted by logansc
That was a great tutorial on overheating rear cylinders---thanks for the info GMC! I have the opposite problem; overheating front cylinders! I'm seeing very high temps during climb that sometimes cool down in cruise (but occasionally don't!). I have to nose the airplane over to 170 to 180+ indicated sometimes to get them to come down. Any ideas? RV-4, IO-360, C/S, "standard" Lycoming 360 GAMInjectors, JPI Instrument engine monitor (all cylinders). My rears are running 330 to 350, the fronts 420-430 during 120-130 mph climb, they slowly cool down after level off, but sometimes still stay above 410-420 for several minutes. Engine sounds and runs well, plenty of power, mag checks fine, leans properly, etc.
Shiloh
The RV4 cowling may be way different, but it still seems physically impossible for the fronts to run hotter than the rears. I'd bet a buck you've got the probes wired backwards. Next flight, disconnect your #1 probe and see which one drops out on your JPI.
Jon Baker
RV6A sold, RV4 in-progress
Houston
