Old 01-20-2008, 07:40 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Best Multi-pin Connectors
I was looking over the ICOM radio I have and it has parts to make the connection with a MOLEX type connector. This got me to thinking what most guys think are the best type of connectors for multi-pin connections, molex, D-sub,..? I am not even close to my panel work but I am laid up and can't build so to keep my mind in the project I have come up with this question. I want to set up the radio in the shop.
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 01-20-2008, 08:47 PM
Rick S. Rick S. is offline
Molex, made by AMP work fine, I really like the gold pin crimp sub-D's but your limited by wire gauge. My entire air frame is set up using Sub-D and AMP connectors....Everything so far has been "smoke" free.
Rick Sked
Old 01-21-2008, 07:30 AM
w1curtis's Avatar
w1curtis w1curtis is offline
I link the AMP Circular Plastic Connectors (CPC). They are readily available from Mouser.
William Curtis
SB RV-10 40237, Status, Panel, Engine, Paint, Me, NE RV-10 Page, Cessna 177RG, AF Missions
?Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.? - Dr. Suess
Old 01-21-2008, 08:21 AM
az_gila's Avatar
az_gila az_gila is offline
Smile Conxall
Similar to the AMP CPC ones mentioned above are the Conxall ones - also available from Mouser.
These are good for smaller bundles, and are ideal for trim servo cables. The bulkhead mount versions can give you more options for location.
http://www.mouser.com/catalog/624/935.pdf
and
http://www.mouser.com/catalog/624/936.pdf
Remember, each connector you use should be different to prevent accidental misconnections.....
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-21-2008, 09:13 AM
scard's Avatar
scard scard is offline
Ahh, connectors. One of any good geek's favorite things. I'm guilty. I've been using "Microfit 3.0" in many low current locations. I have the production crimp tool that makes installation just so easy I have to have a reason to use something else. I'll probably experiment with some of the others mentioned here in the next build just for fun.
Scott Card
CMW E-Lift
Old 01-21-2008, 12:17 PM
rjcthree's Avatar
rjcthree rjcthree is offline
Default Yep . . .
Scott's right. A very rewarding discussion for the inner geek.
I hate Molex. I have personally seen unacceptable failure modes in heavy truck (parking brakes at speed) using molex connectors, manufacted by AMP.
Packard 150 metri-pack series for powering stuff and Deutch DT or DTM sealed for anything under the cowl and signal level stuff. Digi-key, mouser, wherever - in my case, it means the supply cabinet in the lab . In any case, they always have a positive mating lock, and can be saftied with a zip-tie. Generally, they all have secondary pin locks as well.
Regardless, strain relief is the best thing you can do for connector reliability, IMO.
Rick 90432 - running *^&$#$&^%#!!!! conduit through the wing.
