01-20-2008, 07:35 AM
Location: Midland, Michigan 3BS Hanger 4B and sometimes at home
Heated seat reviews?
Last year or maybe longer there was a group buy on heated seats. If I recall several were sold. Here in mid Michigan my thermometer says 5 so Im looking for some warming reviews. BTW great forum, thanks for all the help!
Patrick Howe
Citabria 7KCAB - sold
RV8A FB - flying
01-20-2008, 08:03 AM
I like them
Pat,
I have them in my -9A and really like them. Combined with the dual heat muffs, the cabin is very tolerable down to about 0F outside. The heat on the bottom of the legs and lower back is really nice.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
01-20-2008, 11:30 AM
I'm installing them now
Originally Posted by petehowell
Pat,
Pete,
I think this may help Pat with the decision to go with the heaters. I'm not trying to steal the thread.
I am in the process of installing seat heaters. Can you explain or show pics of your wire routing. I've got the passenger seat figured out. I can run it under the top longeron, back to the baggage compartment and down under that seat. The pilot's side will be more difficult because that location is already taken by static tubing. My spar snap bushings are pretty full.
Joe
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
01-20-2008, 03:19 PM
Heated seats are great! They make a 20F day an nice day to fly
As for the wiring ... we run it on top on the seat plates ... and remove it during the summer.
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
01-20-2008, 03:43 PM
How many amps?
How many amps does one seat draw?
01-20-2008, 04:01 PM
Down the middle and in the flap housing
My wiring runs down the middle thru the spar and up into the the flap motor housing. It comes out of the flap housing to the seats. I don't know what they draw for amps.
Pete
St. Paul, MN
01-20-2008, 05:50 PM
Mine have 10 amp fuses, so I'd guess a bit less than that (each).
Joe Schneider
Flying since 2008
01-20-2008, 06:20 PM
Classic Aero
I was just looking at the heated seats on the Classic Aero site ( http://www.classicaerodesigns.com/we...ctCategoryID=1)
Looks like theirs draw 5 amps each on 'high' setting.
Are these the same ones you're using, or are there other brands?
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
01-20-2008, 06:24 PM
Needed 7 1/2 amp breaker per seat.
RV-6A - N468AC
N468AC Web Site
01-20-2008, 07:44 PM
8A
I have the heated seats but have not installed them yet. Does anyone have any input on installation and wire runs for the 8/8A?
Where did you put the control buttons?
Tony Johnson
RV8A "Badboy" N12TJ
Treasure Island Florida
