Old 01-19-2008, 12:52 PM
C-J C-J is offline
Default EXPBUS 2V Control Visions
Is anyone using the EXPBUS 2V from Control Vision. I am thinking about using it in my panel with the indicator panel. Can anyone share experience. Thx CJ
Old 01-19-2008, 01:00 PM
Randy Randy is offline
CJ,
I am using one and it has worked fine for me, although I have not heard good things about the indicator unit. Feedback I have heard includes poor visibilty of the lights and the ameter function is not good. The company has been very supportive of the few problems I have had, one of which was caused by me, flood damage, and they still sent me a new replacement board. I had water come down on my project from the floor above and it caused corrosion of components on the back of the board, yet they sent me a new one after a full explanation from me as to waht had happened.
If your total electrical loads are going to me higher than about 40 Amps, an off the board master contactor is advised.
Randy C
Old 01-19-2008, 08:13 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
I'm using the Exp 2 bus.
I've only had 1 issue which was self inflicted. They corrected my problem & I've had no issues since.
The instructions were a bit confusing for a non-hardware guy.
Otherwise, I've been very happy with it's operation.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 01-19-2008, 08:35 PM
DarylT's Avatar
DarylT DarylT is offline
I am in the process of wiring mine up now. Looks good so far. I did have a problem with the annunciator panel and when I called for support they were very quick to diagnose and repaired it quickly.
Daryl Tolliver
VAF 1086
Yes: I paid my =VAF= membership dues for 2020
RV-7A - N754RV: Status - Pink Slip is In! First Flight 8/23/12 - My First Flight 9/24/12!
Home from GloCustom for Paint! 3/16/13
957 hours and climbing
7th Condition Inspection complete 10/31/2019
Superior XP IO360 (180 HP), Hartzell Blended Airfoil, AF-5400 EFIS panel, Garmin Aera 660, TruTrak Vizion 385 AutoPilot, Dual Pmags
Houston, TX
Track: SPOT
Weiser Airpark (EYQ)
http://www.rv7a-factory.com
Old 01-19-2008, 09:58 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
An avionics engineer and electronics tech told me today they would be leary of using solid state electrical overload protection in their airplanes. Tripping setpoints can be variable due to numerous effects.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 01-19-2008, 11:53 PM
jclark jclark is offline
Default 1000+ hours ..
Still working.
Had to replace it early due to a water soaking of it and other avionics in our "tip-up 6".
I have and recommend using the external contactor (as documented and supported by them).
The annunciator "indicates" what is on or not properly but the charges/discharge indication is not exactly right ... but that may just be that once it was "close enough in the calibration" I stopped.
Documentation could be a little better but once you understand what they are doing, it makes more sense (of course!) :-)
Otherwise works as advertised.
James
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 01-20-2008, 03:04 AM
kiwipete kiwipete is offline
I'm Happy with mine. However to be honest it is expensive and I don't think it really saved any building time. I remote mounted mine so I could place the switches where I wanted. I was disappointed with the quality of there panel as the writing was poor.The rocker switch's seemed a bit cheap and poor quality.
If I was to do it again I think I'd just go with circuit breakers
Peter
Old 01-20-2008, 04:46 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by kiwipete View Post
..........However to be honest it is expensive and I don't think it really saved any building time............If I was to do it again I think I'd just go with circuit breakersPeter
I agree with Peter. I installed a relatively expensive lighted EXP with its optional annunciator panel in the -6A. It looks nice but in order to support the radios I was installing, a few of its polyfuses had to be replaced with higher amperage ratings so the unit was sent back for rework. Service was fast and adequate. Still, one or two of its rocker switches go unused and are labeled "spare." I still had to install a dozen or so CB's to support the various electrical loads on board. The annunciator panel is of dubious and superflous value......mainly because the VM1000 engine monitor will visually and audibly alert any out of normal parameter. I really can't see how installing the EXP saved me any meaningful build time so I just went with CB's in the current project.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 01-20-2008, 05:07 AM
N131RV N131RV is offline
Smile Tastes great, less filling.
I have had two aircraft with the EXP bus setup. Both used the toggle switches mounted remotely (not the rockers). One in an airplane I bought, one in an airplane I built.
In both cases, the units work perfectly. I have tested their trip/reset capabilities (accidentally and deliberately) more than a few times.
While not for everyone, it is a quality product and did make wiring a basic VFR panel extremely simple.
YMMV
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
