Question about cowl lengths...
I've got my finish kit on order and it should be here in a couple of weeks. I've deleted the cowl, and am in line to order my cowl from James Aircraft. I beleive the "shorty" version is the same as Van's, is this correct? At the moment I am planning an IO-360 with vertical injection with a Sensinich prop to keep my budget under control. I want to be able to have the option to go to a CS prop without messing with the cowl at all at some point down the road. So, if I set my plane up with the shorty cowl, will everything be in the right place? What is the purpose of the 2" & 4" prop extensions?
Any insight in this area would be greatly appreciated.
Dave Chapdelaine
N821RV
RV-7
Flying as of 7/2/11
