Old 01-17-2008, 03:39 PM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Default MK-319-BS rivets and 7/64" holes
Hi, all... am I the only one having problems getting the MK-319-BS rivets into 7/64" holes? Everything I've read says drill to 7/64", but it looks like I'll need to use a #34 or maybe even #33. I've tried multiple 7/64" bits with the same results. Am I missing something?
Thanks...
-Rob
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 01-17-2008, 03:45 PM
Jekyll Jekyll is offline
Jekyll
Old 01-17-2008, 05:00 PM
az_gila's Avatar
az_gila az_gila is offline
Smile #33 should do it....
Thanks...
-Rob
A copy of the rivet specs are here...
http://rapidrivet.thomasnet.com/item...19-bs?&seo=110
The rivet size is a nominal 7/64, but the recommended hole size is given as 0.113 to 0.117
This puts the #33 at the lower end at 0.113 and a #32 near the upper end at 0.116.
Since the holes are usually hand drilled for these rivets, and are a little larger than the drill size... the #33 fits right in with the specifications.... If it's tight, then use the #32.
For reference, a 7/64 drill is 0.1094... giving a hole a few thousands tight as you found out....
The folks using their 7/64 drills are probably drilling sloppy holes.
gil A- reading those specs. again...
ADDED
This web site looks better for specifications, including hole drill sizes, for commercial pop rivets.
http://www.hansonrivet.com/w18.htm
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-17-2008, 05:06 PM
TSwezey TSwezey is offline
Instructions call for a #33.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 01-17-2008, 09:51 PM
RV10Rob's Avatar
Thanks, all... that's what I figured--the spec for the rivet is bigger than the hole, and my micrometer told the same story. I was just confused since *every* place I've looked says 7/64" (including the -10 plans where I'm working now).
-Rob
Rob Kochman
Paine Field (KPAE)
EAA Chapter 1440
