Old 01-16-2008, 12:29 PM
dpansier's Avatar
dpansier dpansier is offline
Default Low cost collision avoidance system
If this system finds its way into everyday cars it may have applications for aircraft use.
The following from the latest NASA Tech Briefs,
?European researchers have demonstrated a collision warning system for cars that could alert the driver several seconds in advance of an imminent impact. The device could save thousands of lives and usher in the first steps towards the "connected car." The system, based on inexpensive software, is called the Collision Warning System (CWS), and is the brainchild of the Reposit "relative position for collision avoidance systems" project.?
http://www.ist-reposit.org/index.php
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Antennas for Experimental Aircraft
www.deltapopaviation.com
