01-16-2008, 06:55 AM
Cheap ratchet straps
I am now replacing a skin on the horizontal stab because it fell from the ceiling where it was stored. I had some Harbor Freight ratchet straps lying around and decided to hang the tail parts up to get them out of the way. I knew they were cheap straps but with 2 straps on the horizontal stab without the elevators attached I thought what could possibly go wrong. After about six months one strap unraveled and let the whole thing fall about 8 feet. You can literally pull the straps apart with your bare hands. These straps have never seen sunlight or moisture. I never even considered testing them with so little weight. The picture shows where I pulled them apart with my hands. The straps look brand new.
Maybe this will keep the same thing from happening to someone else.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
01-16-2008, 07:06 AM
Thanks for the heads-up, Jim. I have a bunch of these straps that I use regularly. I'll be testing them before each use from now on.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
01-16-2008, 07:18 AM
Wow. Me too. In fact my tail feathers arehanging from the ceiling with some of those very same straps. Gotta run ......
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
01-16-2008, 07:54 AM
Several people have reported that mice will actually cause this problem. They like to chew through that stuff to make nest with the material.
01-16-2008, 08:26 AM
VAF Moderator / Line Boy
I have been averse to using "cheap rope and lines" for most of my life....back when I was young teenager, I helped rebuild a couple of J-3's. We spent months putting the wing structure together (the needed new spars), and after we got everything lined up and perfect, ready for cover, we tied ropes to them to hoist them up into the hangar rafters until ready to cover. They got almost all the way up before the cheap clothesline broke, and they came crashing down. That was the end of THAT set of wings.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
01-16-2008, 09:43 AM
no doubt
ive used the cheap ones for boat tie downs and they always break or pull the thunb lever back ove..the cheap ones (ratchet or pull) just ar not worth a flip.
William Weesner/ still kicking.
01-16-2008, 09:51 AM
I first thought of mice too until I pulled them apart with my bare hands. I bought straps from other sources like Wal-mart and never had problems.
Jim Wright
01-16-2008, 10:14 AM
poly web
Here at work we use different styles of webbing and we found that polypropylene will deteriorate quickly when exposed to UV light. Nylon and polyester webbing hold up much better in the sun and have a much higher working load. Quality load straps should be made out of nylon or polyester and sewn with polyester thread.
When I first read your thread It looked like polypro webbing that had been exposed to UV. The only webbing that I have seen rot like that are those made from natural fibers such as cotton or something. If those straps were made from a synthetic then I would say it is some cheap stuff and that the "molecules stopped holding hands"
Bruce Smith
Clearwater, FL
RV-7A Fuse
N27DB reserved
web.tampabay.rr.com/flrv7a
"Political correctness is tyranny with manners."
Charlton Heston
01-16-2008, 10:27 AM
What I did to hang my stuff was drill through the joists above the garage for 1/4" threaded rod. Four 3-foot rods were installed down through the ceiling and then I suspended angle iron between pairs of the rods. A little foam weather strip cushioned the angle where my parts rested on them. Or you could use plywood (though I'd still support the wood with the angle) and then even smaller bits could be stored up there. If your garage has an open ceiling you could still adapt this idea by using anchors in the roof joists; my dad used to do that in his pole barn/garage on his farm.
