And here's what we did,
RV-7A tip-up, result looking great!
we did a few mods to the frame to prepare for the sikaflex:
and basically cou can finish the frame including the rear latches and weatherstripping before ever putting on / trimming the plexi as opposed to van's instructions where you'd wait e.g. with drilling the rear top center splice plate.
first, the "canopy stop" idea that has been floating around here is highly recommended, otherwise installing the gas struts will skew everything:
then we did some custom weatherstripping, which is awesome:
now to the actual mods on the frame:
- the siderails are mounted to the inside instead of the outside (plans) of the weldment, essentially resulting in an offset to the inside of .125". between the weldment and the bracket attaching the siderails are small spacers.
then there are 2 .063 strips with lightening holes clecoed to the siderails. on that the canopy will rest/can be clamped while the default top bend of the siderail will allow for a very nice bead on the inside of the canopy, giving enough sikaflex to hold on to. The sideskirts are later installed only with the rivets through the siderails and sikaflex between the canopy and the skirt, we have 0 holes in our plexi :-) also the rear canopy frame rib was built slightly undersize to give the canopy a nice sikaflex bead while resting flush on the rollover bar. also, no need to wait with installing the canopy frame top skin as per van's. when you're at the point, just rivet it on before plexi work.
and the actual gluing:
http://www.flyvans.com/log/2008_04_0...ex_canopy.html
http://www.flyvans.com/log/2008_04_1...x_canopy2.html
we made one mistake:
with the big cut, thought it was a good idea to move that away from the centerline of the rollover bar forward onto the flange of the forward rib. the idea being, that the rear canopy will have a stronger bond plus that ridge between the ribs where you can see the straps would be covered.
problem it turns out was, the forward canopy was now sitting flush while the rear canopy was "trumpeting" over the rollbar and the big cut didn't look good any more. we fixed it by trimming the rear canopy as well and filling the void with a solid sikaflex bead. that used about another cartridge but the end result looks good and we have a 0/0 sealed canopy :-)
observations:
-get enough helpers
-anywhere where there's no sika primer, sikaflex won't stick and can be easily removed by rubbing it off. best done about a day after while it's still relatively soft. use that to your advantage.
- get good quality electrical tape that doesn't leave too much residue.
- the quality of the joint is awesome, sample pieces (with adverse conditions, no cleaning, no scuffing) had the plexi break before anything would let loose.
- also the tip with sanding the sika with 120grit works perfectly. just make sure you "plaster" enough sikaflex on so you can sand it down and aren't left with any voids.
- get enough sikaflex. most descriptions mentioned about 2 cartridges, we had to order more, certainly used 3 for the "regular" front and rear canopy and used a fourth (but that was used to cover our big cut building mistake)
one gets probably sanded away again when you shape the fairings ;-)
kind regards,
bernie
