01-15-2008, 01:16 PM
Type Designator for flight plan filing?
What Type Designator do you use when filing IFR?
I've been using RV7, because I thought I saw it as an FAA recognized Type Designator. Now, I can only find HXA, HXB or HXC. I guess I should be using HXB.
Anyone care to comment?
Mike
01-15-2008, 01:31 PM
HXB is what I have always used
Milt Concannon
01-15-2008, 01:52 PM
fugio ergo sum
I use RV6 and it works. ICAO says RV7 works also. http://www.icao.int/anb/ais/8643/index.cfm
Nothing wrong with HXB but they are probably going to ask you about the type then.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
01-15-2008, 02:50 PM
VAF Moderator / Line Boy
I've used RV8/G and never had a problem
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
01-15-2008, 03:12 PM
Originally Posted by n5lp
Make sure you put in Van's for the manufacturer ..... program is not particularly intuitive!
Dave Durakovich
CFIG, AGI, COMM SEL, VAF# 133
RV-4, N666PR, Finished (Well, at least flying)!
RV-6 - Adopted an orphan!
Detroit, MI
"If you think you can do a thing or think you can't do a thing, you're right."
Henry Ford
01-15-2008, 04:10 PM
Why do they ask?
I don't want to hi-jack this thread but I am curious. I am sometimes asked make & model when using flight following, sometimes after being passed off. Why do they ask? I always say "Vans RV-7" and they seem happy with that. What gives? Thanks.
Hugh
Northern California
RV-7 Flying
01-15-2008, 04:42 PM
I've always assumed it's for spacing. They probably want to know how fast you can go.
Jorge Martinez
QB 8A Fuse. Just battled the ^%&@ing gear weldments. Now I can move on.
http://www.rv8alog.com
01-15-2008, 05:00 PM
And how fast (or poorly in the case of a spamcan) you can climb.
Neal Howard
Airplaneless once again...
01-15-2008, 08:32 PM
equipment type
I work as an air traffic controller and the RV series id's have all been added into our system (enroute). HXB would be used if you were a less known experimental homebuilt. Filing a RV6, RV6A, RV8, etc., works just great. It also gives us ATC folks with RV's a chance to say Hi!
01-15-2008, 08:52 PM
Yes, its usually because of climb rate and airspeed.
