Old 01-14-2008, 02:38 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default Rivets for attaching plastic NACA vents to skin
For those who riveted their plastic NACA vents to the fuse skin, what size rivet did you use? I would like to use MK319's left over from the canopy but not sure if they have sufficiently long grip. Normally I would just test this myself, but I only have the exact number I need... I can't afford to waste one on a test! Should I give them a go or just use the larger CS-4's?
(Yes, I know I could probably get by with just proseal and no rivets at all... but I'm past that stage.)
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 01-14-2008, 03:27 PM
RV6_flyer's Avatar
About 15 years ago, I attached my NACA vents with proseal. My RV-6 has now been flying 10 years as of September and I have over 2,074 hobbs hours on it. No problems with the vents. Cannot see even a crack. They look just like they are part of the airplane.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 01-14-2008, 03:37 PM
Thanks Gary, but notice the last line of my post. I'm past the stage where that is an option.
Steve M.
Ellensburg WA
Old 01-14-2008, 03:42 PM
Warren Moore Warren Moore is offline
you can always make a flange of .016 alum. around the vent for the rivets to pull/seat against. But I would still proseal it in any event.
Old 01-14-2008, 04:02 PM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
I made two small half moon doublers out of scrap aluminum and then a thin layer of proseal and used normal flush rivets but soft set. No problems with distorting or cracking the vent and gave a very nice clamping force.
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
Old 01-14-2008, 04:09 PM
How did you clamp it 'til cured. Or did you?
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 01-14-2008, 04:10 PM
This thread is a great example of thread drift...
Back to the original, and only, question... can anyone tell me if MK-319's have sufficient reach to get through the skin, through the vent, and through an .019 backing strip?
I'm trying to get this done tonight, hence my persistance.
Steve M.
Ellensburg WA
Old 01-14-2008, 04:15 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
You guys are a bunch of whoosies. I put mine on with AN 3 rivets.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 01-14-2008, 04:16 PM
Rick6a's Avatar
Rick6a Rick6a is offline
The best way to know for sure is to make up a simple stackup simulating the total material thickness and set a MK-319 through it.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
frankh's Avatar
frankh frankh is offline
Default Whats wrong
with standard #3 rivets...Just cut some little scraps of alu and drill #40 holes to make backing washers and then drive them with the rivet gun just enough to hold 'em.
Worked fine for me...Goop optional...I used some paintable duct sealant.
Frank
