Old 01-14-2008, 08:14 AM
rv4bill rv4bill is offline
Default 0320-d2j
Can someone tell me if the 320-d2j can support a constant speed prop?
Old 01-14-2008, 05:48 PM
Steve Sampson Steve Sampson is offline
Bill - I think from the doc at the link enclosed the answer is 'no'.
http://www.prime-mover.org/Engines/L...Cert_list.html
But I would suggest you check my understanding.
Perhaps an electric MT prop? I used that on the -9a I built, though I guess its not right on a -4!
Good luck.
Steve
G-IKON Build log here , or Index to blog here.
RV4 #4478 - Flying since 16th June '08. First flight video here.
Circuits at my 1000' strip.
Old 01-14-2008, 07:03 PM
DickDe DickDe is offline
Default C/S prop
I converted an 0320E2A to a C/S prop and this is an engine that is listed to have a solid Crank (but Mine was hollow), the crankcase was not supposed to have a tapped hole near the front end (mine had the hole with a pipe plug sealing it) and the accessory case was not supposed to have a pad for the governor (mine had a plate covering the hole). Lycoming, when asked about the feasibility of a prop change, said the engine should not be capable but, in production, they may not have the proper components handy and they use what they have which will work. Therefore, a person has to look to see what you have regardless what the specifications say. I was lucky and you may be as well. I must have about 75 hours on the new prop.
Dick DeCramer
RV6 N500DD
RV8 in the works
Northfield, MN
Old 01-14-2008, 08:39 PM
My RV-6 has a D2J. It has a governor pad, but it is not machined or drilled. I'm sure you could have a certified shop machine the case, but that involves a complete tear down of the engine.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
