01-13-2008, 11:57 AM
How to direct cooling air to magentos, alternators, etc.
What have you guys been doing to direct air to some of your "heat sensitive" devices (mags, alternator, etc). I planned on using a section of 1" SCAT hose with air taken off the baffles to do this, but I'm not finding a good way to get the exit portion of the hose lined up with the accessory. In other words, the hose is very flexible so it needs some kind of "anchor" to direct the flow at the accessory I'm trying to cool.
How have you guys been doing this? I'm thinking a WDG clamp would work but I'm not finding a good place to attach it that will still provide flow in the right direction - there aren't any convenient attachment points for the clamp. .
I considered a piece of 1" copper or soft aluminum tube that could be bent into the required shape - anyone tried this?
Rick
01-13-2008, 12:25 PM
Rick,
Some people including myself have installed a 1/8" brass or steel spine in the blast tube. This can be done by threading the 1/8 material for a 6/32 steel nut and locknut combination. The spine can then be bent to direct the blast tube where needed. See the photo for clarification.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
01-13-2008, 12:56 PM
I like Joe's idea but I used Adel clamps to hold them in place.
Look close at these pictures and you will see the clamps holding them in place.
Unfortunately I don't have any pictures of how I held the alternator blast tube in place. I tied it to the bracket with some lacing.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
01-13-2008, 11:35 PM
Which way is the air trying to flow in the alternator?
I have been puzzling exactly where to direct the air at the alternator. It looks to me as though ,on the ND 40amp alternator that Aerosport Power sell, the air is pumped from back to front. Can anyone confirm this? If so, I am assuming it is best to aim the blast tube at the square grill in the shroud on the back. (If it were pumping the other way I would just aim at the front.)
01-14-2008, 12:48 AM
My alternator had a nice tapped boss already on it. A metric bolt and an adle clamp worked out great.
Cam
Cam
Santa Ana, CA
RV-9 at KFUL
01-14-2008, 01:02 AM
Ditto on that question,
I got an airplane power 60A altenator, it suppose to be turning the correct way, or that is what i read 2nd hand somewhere, so I aimed my hose at the front. But I also would like someone to confirm for me.
PS Also where to point scat tube at Mags, front or back???
Thanks, Kind Regards
Rudi
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Reason: Typing errors
01-14-2008, 04:58 AM
back
the instructions for plane power say to direct air toward the back.
I used tie straps/tywraps to encourage the convoluted hose to point in the correct area (back of alternator [attached directly to cooling holes of unit] and body of the mag).
james kleen
savannah
RV8sp - RV3
01-14-2008, 05:35 AM
cooling air
Heres how I supported my alt blast tube. Just fluted up a piece of .032 angle, formed a tab, and clamped it in place with the scat tube to a 1 inch flange.
http://img441.imageshack.us/img441/1342/dsc00593jv5.jpg
real sturdy
Hope this helps!!
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
