01-12-2008, 06:20 PM
Building up your own engine questions
I am starting to get serious with making an engine selection for my 9A. I have a retired friend who is an A&P, Tech Counselor and former DAR who has volunteered to help me assemble an engine from a kit of parts if I can get all the parts. When I search for kit engines, however, I only find places where a parts supplier will supply a kit of parts to a commercial engine builder. So, if I want to build up my own engine with the help of my friend, is there a supplier who will sell me the parts directly?
Now that I have asked the question, even with an experienced helper, does it make sense to build up your own engine? I mean, do commercial builders add any value when they build your engine, such as doing balancing, etc? Also, how much money might one be able to save by building up their own engine? Any other downsides to building up your own engine?
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
01-12-2008, 06:35 PM
It absolutly makes sence to build your own up from parts, contact A.E.R.O. in stock. They have a link on the front page of VAF. Call the Granite City location and talk to Jesse. He'll be able to have an engine kit shipped to you from ECI. The picture below is the one I built and is hanging on the nose of my plane. I have a new O-360 assembled from a kit (not the one shown here) that I'm willing to let go for $19,750.00 plus shipping if anyone is interested.
01-12-2008, 06:47 PM
I went this route in my -6A and it was really the most rewarding part of the project (other than flying).
I bought the runout core, securing a written guarantee that if the crank was bad the seller would provide a serviceable replacement. The IA helped me determine which components were serviceable and what needed replacement. I then shipped pieces all over the country based on ads from trade-a-plane. I opened an account with Superior for parts that needed replacing. I visited various booths at Oshkosh to take advantage of show specials.
If you elect to buy new cylinder assemblies (what I did) you reduce the complexity of the project quite a bit.
As long as the IA is willing to give you guidance along the way, you can save quite a bit of money and remove a lot of the mystery about your engine.
John Allen
01-12-2008, 06:49 PM
Rivethead mentioned where to get one. ECI kit is already balanced.... so you don't have to worry about that.
And the only (that I can think of) downside is lack of warranty. Yes, you'll get warranty on parts.. but not engine assembly. If something goes wrong, it can be costly. Though there are many, many upsides to doing so... I'd definitely strongly recommend having some sort of supervision/help from someone with experience.
Radomir
RV-7A sold
01-12-2008, 08:23 PM
Just want to echo the route of going to Jesse at www.aeroinstock.com. They were great to work with and I got an 0-360 kit for a little under $14k (shipped!). I still had to buy a carb, starter and electronic ignition. All in all I think I spent $17k for a complete brand new engine & a small portion of that went to the A&P I/A that helped me build it (OK, more like I helped him).
I think that if I would have used regular mags, I could have gotten a "data plate" and have a certified engine. But who wants regular mags?? (Just kidding!).
Sonny W
Boise, Idaho
RV-7A Flying!
01-12-2008, 08:27 PM
I purchased a runout engine and rebuilt it for my plane. I had the assistance of two AI and A&P's during the process. I learned quite a bit during the process. I'd do it again.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
01-12-2008, 09:04 PM
IO320 Cost Difference
I was originally thinking about going the kit engine route, however I read somewhere that there is very little cost benefit over Van's engine deals. Is that true?
01-12-2008, 09:36 PM
VAF Moderator / Line Boy
These are really old numbers (about three years), but I recall that the difference between and ECI kit and having Mattituck build the ECI kit with a few of their own modifications (things they have learned over the years to prevent oil leaks for instance) was about $2K. Yeas, that's a lot of money, but I decided to let them do it that time, and I went up there to watch. I might very well tackle it myself next time, now that I have seen some of the techniques and gotten good instruction!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
01-12-2008, 10:46 PM
Depends on the ECI distributor...
Paul
Paul... I think the $2K difference is from ECI dealers who would rather sell you a completed engine instead of a kit.
Jesse at A.E.R.O. does not have an assembly shop, and, since he only sells kits, they seem to be discounted much more than the other ECI distributors.
My personal calculations are a bit unique since I have most accessories already, except for the carb. - but I think the difference is much closer to $5K for a "full" engine with an ECI kit from AERO. This estimate seems to fit in with Sonny's numbers above.
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
01-13-2008, 05:30 AM
After attending Mattitucks workshop, I'm inclined to let a shop build my engine. The discussion during the workshop about clearances leads me to beleive that this is something I want done by someone/someplace who has access and experience to manufacture the best clearances. For example, one item discussed was the new clearance tolerancefor the piston to piston pin. It was .0008 - .0021. The mechanic explaining the process said it was their experience that .0008, while in spec, did not allow room for proper lubrication and more wear (metal) than desired would occur. If assembled at the high limit of the tolerance, .0021, experience has showed them that those parts would have proper lubrication from the get go and there would be almost no wear at all. This is just one example of what was shown to us during the workshop.
Mattituck takes kits like the ones from ECI and sends them into their inspection dept where all clearances and tolerances are verified. If they are not what they consider optimum, then the parts are replaced or machined to obtain the proper ones.
To me, it is worth the extra 2K or so to have this done. I'm sure there are many engines built that run fine from straight, non inspected kits. I also know from working in the areospace industry manufacturing jet engine parts that it would be impossible for most homebuilders to accurately verify the tolerances on the parts they have.
The actual assembly of aircraft engines looks to be very straight foward, and I think most of us could put the parts given together without much difficulty, but there is much more to these things than meets the eye.
I really enjoyed the post by another VAF member Captain Avgas concerning the "old" aircraft engine technology. http://www.vansairforce.com/communit...ad.php?t=25456
After attending Mattitucks workshop I am convinced that indeed the lycoming type engine is the perfect powerplant for light aircraft, and is manufactured to a very high degree of precision and refinement.
My hat's off to those who want to reinvent the wheel, (auto engine folks) but I'd rather fly
Dave Chapdelaine
N821RV
RV-7
Flying as of 7/2/11
