Originally Posted by GaryK
I've flow to the Bahamas a couple of times in a Commander 114 but never in my RV7A. In the past you had to get prior approval to fly an experimental into the Bahamas, is that still required?
Thanks for your help
Gary
N715AB
No you do not need prior approval. Ive never been asked for the doc below, but its the current legal precedure. Log into EAA's website and get it.
"The EAA has worked (successfully) with Bahamian government to streamline this procedure. In order to meet your operating limitation requirement, print out the approval letter at the following website, meet the requirements of the letter and carry it on board your aircraft. With this authorization letter, your homebuilt is treated the same as any other US or Canadian registered standard category aircraft flying to the Bahamas."
http://members.eaa.org/home/homebuil...rs/bahamas.pdf
Best,
