Go Back   VAF Forums > Main > Reviews
  #11
Old 01-12-2008, 08:02 AM
algrajek algrajek is offline
The super Dry is TOO exoensive for what we use it for. DO NOT use Deise or Concrete form oil(they are flammable, and stink!). I use the Canopus in my RV8. Its cheaper, and burns really clean.
Al Grajek
Old 03-02-2009, 02:54 AM
a25afm's Avatar
a25afm a25afm is offline
Talking Smoke oil
Where can I purchase Texaco Canopus #13 oil in the Los Angeles area?
Alex Margheritis
RV-8 N214MK
Flying since August 2007
Old 03-02-2009, 01:30 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Originally Posted by lcnmrv8r View Post
I thought Canopus was a concrete form oil??? I read this somewhere else
"- Diesel & Concrete Form Release Oil 50:50 (obtained from construction industry goes under the name of Chevron/Texaco "Canopus 13" oil [formerly called Corvus Oil], EXXON Unuius-15, SUNOCO 222, Corbisol.)"
Concentrated antifreeze works too. The problem with most of the "home recipes" is that they stink and make a mess.
How often are you going to use it and how much will you use? answer those questions and it may make sense to just buy the good stuff.
Headsup on antifreeze... Fatal to humans/animals if ingested. Don't know about breathing it but would def not take the chance...
Jerry
Old 03-02-2009, 01:56 PM
DanH's Avatar
DanH DanH is offline
<<Where can I purchase Texaco Canopus #13 oil in the Los Angeles area?>>
Look for a distributor in the phone book under "Oils, Lubricating". Usually need to order a 55 gallon drum. Around here I had more luck with a Shell distributor and ordering Carnea...same thing as Texaco Canopus, plain mineral oil.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-02-2009, 04:58 PM
RV6_flyer's Avatar
Not sure if they have it but they may be able to get it. They have good prices on Aviation engine oil.
http://www.apfischer.com/
Phillips XC 20W50 is $20 a case cheaper then at Aircraft Spruce and A.P. Fisher is closer to where I live.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 03-04-2009, 04:59 PM
SteinAir SteinAir is offline
Not sure about where you live, but around here we found an oil distributor and purchase our smoke oil from them. Concrete Form release oil is what to get! I'll check my barrell and see what brand/type it is and then report back.
Stein
