Old 01-09-2008, 09:02 PM
lancef53 lancef53 is offline
Default Where do I find RPM restriction for IO-360A1A???
This info has to be on here somewhere, but I can't find it. Where do I find the information on RPM restrictions, specifically for a IO 360 A1A engine with a Hartzell CS? How about with a fixed pitch?
Thanks for the info, Lance
Old 01-09-2008, 09:42 PM
Transporter Transporter is offline
Default Type Certificate Data Sheets (TCDS)
Type Certificate Data Sheets (TCDS) list engine/prop combinations (and restrictions). TCDS information is available from the FAA at
http://www.airweb.faa.gov.
Click on the TCDS link in the lower right, then do a "Current Model (TC Holder)" search for the engine...look up "L" then navigate down the list to Lycoming...then find your engine model. Operating restrictions are shown for each engine.
You can also look up TCDS for the prop...look up "H" then navigate to Hartzell, then look up the model number, etc. Operating restrictions will be listed in the table for the prop/engine combination.
Good hunting,
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Last edited by Transporter : 01-09-2008 at 10:17 PM. Reason: Added prop/engine comment
Old 01-10-2008, 05:43 AM
Default thanks!
Thanks for the info, so according to the info on the Hartzell pages, with the propellor vans sells, (C2YR-1BF/F74972 or F7497)continous operation above 24" manifold pressure between 2350 and 2550 is prohibited, correct?
Thanks --does anyone have any experience with this? Is it a big problem to work around? Thanks for the help--Lance
Another question, is it possible to find out RPM restrictions for a wood experimental fixed pitch prop? Do you just have to check with the manufacturer?
Old 01-10-2008, 08:55 AM
az_gila's Avatar
az_gila az_gila is offline
Smile Wood props
Check with the prop maker, but I believe the flexing/damping properties of wood prevent resonances at specific frequencies (RPMs) so they should have no RPM restrictions....
Has anyone got a wooden prop with an RPM restriction?
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-10-2008, 10:51 PM
Default Fixed Pitch
Lance,
Lots of data out there (and I'm sorting through it myself as I begin to research engine and prop combinations for my 8).
Sensenich has a table with various FP prop recommendations for RVs at: http://www2.sensenich.com/direct/vans.htm
FWIW, I flew an RV8 with a composite Catto FP (O-360, 180hp, two-blade Catto) last Sept and it was very smooth. Other threads here have also been positive regarding Catto props but the Catto website doesn't have a lot of technical info so you'd need to contact them for specifics.. www.cattoprops.com
With regard to your question about CS rpm restrictions: The restrictions typically state "no continuous operation" with a certain power setting (like the example in your post). As a generality, you use the prop and throttle settings as needed for takeoff and initial climb, then pick a combination that avoids the restriction during cruise climb and cruise. Manifold pressure changes with altitude, so whether or not the restriction is a serious consideration for a given flight depends on how high you're flying...Yes, it's one more thing to think about, but if you're flying the same plane on a routine basis it's not a big deal.
As I looked at the TCDS for the prop you listed (same as sold by Van's) I'm sure there's a good reason, but can someone explain why there's a difference between the O-360-A1A and the IO-360-AIA regarding CS prop restrictions? Are there internal differences between these two engines that would affect harmonics? Maybe an A&P or prop expert can comment?
Mike
Mike Dooley
RV hitchhiker
RV8 SB
Old 01-11-2008, 09:45 AM
Jekyll Jekyll is offline
http://www.hartzellprop.com/kitplane/index_kitplane.htm
Also, drop Hartzell and email with all your particulars such as engine, prop, type of ignition and they will be happy to provide the exact restrictions for your setup.
Jekyll
Old 01-12-2008, 08:39 AM
Pirkka Pirkka is offline
Originally Posted by Transporter View Post
Type Certificate Data Sheets (TCDS) list engine/prop combinations (and restrictions). TCDS information is available from the FAA at http://www.airweb.faa.gov.
One note for everyone trying to look TCDSs or similar... Firefox has some problems showing page correctly (or the page has been done incorrecly). So like if there is more to show, Firefox doesn't show "Show more..." for me at least even it does so with IE.
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
Old 02-23-2008, 09:48 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Lycoming SB or SI or SL
If you are talking to official red line yes the type spec.
If you are talking about how much you can exceed that, its a service letter, bulletin or instruction. I recall its about 5% over before Lyc gets draconian and recommend tear down. So we are talking 2,825 rpm. This is by my memory so by all means check the Lyc publication. They have a whole matrix diagram an it varies with some engines but the 5% is what I recall.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 02-23-2008, 11:03 AM
Kevin Horton's Avatar
These are two quite different engines - 180 hp vs 200 hp, parallel valve vs angle valve, different pistons, possibly different cranks and rods. Given the substantial differences between the two engines, and the different power vs rpm curves, there is no reason to expect them to have the same prop restrictions.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 02-23-2008, 02:28 PM
Default Lycoming Tech
Kevin,
Thanks for the response.
I'm researching engine (and prop) options for my 8 and would like to know the tech details.
Differences between engine models are expected...but it looks like Lycoming has been working on some kind of Guiness record for model variations!
Can you recommend a source for tech info on Lycomings that shows what components are in a given model?
Mike
Mike Dooley
RV hitchhiker
RV8 SB
