Old 01-07-2008, 07:46 PM
NYTOM NYTOM is offline
Unhappy Landing Light Lens question
In the process of installing a DUCKWORKS lens in my wing I discovered that the template "A" doesn't show the location of the six holes for the lens retainer clips even though it says it does. I bought these lights so long ago we had a Democrat in the White House. Would anybody know off hand what the dimension is from the edge of the lens hole at the center to the middle hole of the clip? I tried sizing them off the many pictures I have of RV's and it looks to be about a half to 3/4 inches or so but before I start poking holes in the skin I thought I better run it by you guys. If I can get that one measurement I'll be good to go.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
Old 01-07-2008, 07:59 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I just happen to have the print....
5/16" is the dimension.
Cutout is 5" wide by 5 1/2" high
L.Adamson --- RV6A
Old 01-07-2008, 08:10 PM
Smile Thank You Mr. Adamson
That makes sense. The closer to the edge the better the seal. Thanks for helping me out so quick, I do appreciate it.
Tom
Tom Norwood
TMX-O360. Phase 1
Old 01-07-2008, 09:10 PM
whifof100ll whifof100ll is offline
Default Sealing lens
I have a Clinton Era Duckworks light as well.
What's the recommendation for sealing the lens surface to the skin?
Dale Lambert
RV-6 Flying, XPIO360 Catto 3bld AFS3500EE
'68' C177
Old 01-07-2008, 09:27 PM
JonJay's Avatar
JonJay JonJay is offline
The kit comes with some adhesive foam strips. They do not work well at all and I just trashed mine. I believe there are some threads somewhere you might search on how people have sealed them. It is quite common not to use anything, as many people have done including myself.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 01-08-2008, 04:04 AM
My kit came with extremely thin (1/8") weatherstripping. It's pretty lame. I agree and I'm not going to use anything. The stripping looks like a dirt collector.
Tom Norwood
TMX-O360. Phase 1
Old 01-09-2008, 08:35 PM
Little_Richard Little_Richard is offline
Default Just give Dickworks a call or email.
I am sure the guys at Duckworks would be more than willing to help you with any dimensions or other questions you may have about landing lights.
http://www.duckworksav.com/Contact.html
Old 01-10-2008, 12:13 AM
TheDuck TheDuck is offline
Default Template
Tom,
The Duck here, unfortunately 'a few' kits went out with that template that didn't have the holes on it, sorry about that. Mr. Adamson is correct in his dimension.
As to the 'lame' foam tape - I chose that 3/16 x 1/16 grey tape to seal the lens to the skin because it will compress to the thinness of a sheet of notebook paper. So after you fit the lens, the 'seal' doesn't work against you and push the lens away from the skin.
It's not perfect, but I think it works pretty well.
BTW - in the newer instructions I recommend that you trim the corners off of the nutplate strip on the top to allow it to fit inside the curve of the lense better. This was a tip from builders who gave me that feedback, which I appretiate.
Send me an email and I'll return a pic of that.
duckworks@comcast.net
And please, feel free to contact me.
Don
Old 01-10-2008, 04:55 AM
Kyle Boatright Kyle Boatright is online now
I pulled my lens off a couple of weeks ago. First time in 7 years. The cheesy, thin weatherstripping was very well adhered and seemed to be doing a great job of sealing the lens. This surprised me because when I installed that weatherstripping, I thought "this stuff is junk, but I'll use it anyway".
I recommend using it. It works...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-10-2008, 04:14 PM
Red face I'm Sorry Don
Originally Posted by TheDuck View Post
Tom,
As to the 'lame' foam tape - I chose that 3/16 x 1/16 grey tape to seal the lens to the skin because it will compress to the thinness of a sheet of notebook paper. So after you fit the lens, the 'seal' doesn't work against you and push the lens away from the skin. It's not perfect, but I think it works pretty well.
Don I have to apologize here. After I read this quote a few minutes ago I ran down to the shop to check my kit because I swore that what I had was very thin white foam stripping like you'd find at the local Home Depot. I was almost hoping I had some early type that you had abandoned for the gray tape since my kits are so old. I had been supplied with some of the white stuff with a hatch kit for a boat and it disintegrated within a year.
What I found was exactly what you described. I was actually looking for something similar today but couldn't find anything thin enough like yours.
I am going to use the gray tape now but I really wish it was a little wider. Maybe 3/8 or so but then that's just me.
Other than that the lights are a perfect match for the RV.
Tom Norwood
TMX-O360. Phase 1
