Old 01-06-2008, 05:34 PM
Craig23's Avatar
Craig23 Craig23 is offline
Default Firewall Help?
Hi everyone,
I drilled a hole in my RV-8 firewall to run the cable to my aft battery, but am now going to put the battery on the firewall because I'll be using a lightweight (Whirlwind 200RV) prop. What is the safest way to plug the unused hole in the firewall? It is 3/4" in diameter and on the far left side.
Thanks for the help,
Craig Schwartz
RV-8 (Flying!), IO-360B1PC2 (180 hp, 1 P-Mag, 1 Slick Mag), Whirlwind 200RV, AF-3500, G496, Digiflight II, Classic Aero Sportsman Ultraleather Seats
N868RV
Santa Rosa, CA
Old 01-06-2008, 08:49 PM
vbpiper's Avatar
vbpiper vbpiper is offline
Default Firewall plug
Van's sells a 3/4" stainless steel plug used to fill a hole in the firewall of the RV-7A (and others?) where the nose gear bolt attaches. Part number is "FF 3/4 Firewall plug" Sounds like just what you need! Seal it with a little hi-temp RTV or, better yet, the sealant used to seal the perimeter of the firewall.
RV-7A Finish kit
Renewed 8-14
Old 01-06-2008, 10:05 PM
Jekyll Jekyll is offline
ACE Hardware has a large selectin of plug in various sizes. Save yourself the shipping and stocking fee charges.
Jekyll
